300tdi died won't restart - Defender Source
Old August 3rd, 2009, 05:10 PM
discotdi
Todd Miller
Land Rover
Today my 300tdi disco died in the driveway and won't restart. It cranks and turns over but will not start and run. Here is what happened. Drove into driveway and stopped, turned off the A/C and the car died. tried to restart and it just turns over but will not start up.
Fuel pump? IP? I don't smell diesel when I am cranking it.
Old August 3rd, 2009, 05:42 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Check to see if you have 12 volts to IP solenoid when key is to position II.
Crack pipes open slightly at injectors and see if diesel is getting to injectors.
My money is on number one
Old August 3rd, 2009, 10:17 PM
discotdi
Todd Miller
Land Rover
thanks a million Chris! checked the wire to the IP and all lookede ok, but with a slight tug the wire came off, then when i pressed it back on and held it in place, eureka it started. So I put on a new connector and all seems good. The D90 source pros strike again! Again thanks saved me $$$$ I am sure.
300tdi, start, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
She died! rustydefender Misc. Chit-Chat 5 January 5th, 2005 08:24 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
