300tdi Cylinder Head - Where To Buy - Defender Source
Old January 30th, 2016, 12:41 PM
kzack's Avatar
kzack
Keith Zack
none
It's likely that my cylinder head is cracked and will need replaced. Is there a source or vendor that is considered 'go-to' for cylinder heads? Places to avoid?
Thanks, Keith
Drive the Best - Drive a Hammond
Old January 30th, 2016, 01:22 PM
Here: 300TDI engine parts from Turner Engineering, LDF500180 cylinder head with a variety of options.
Old January 30th, 2016, 01:44 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
We have one in stock if you need it Tuesday.
CYLINDER HEAD FOR 300 TDI WITH VALVES INSTALLED, LDF500180, RNL910, 300TDICYL - Rovers North - Classic Land Rover Parts
Old February 2nd, 2016, 02:03 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
I got a new cylinder head from here after my return from Morocco and after my head gasket blew.
I've had it on my 300tdi for about 200,000kms without issue.
Works out at about 575 dollars plus postage. Comes with engine bolts,original gaskets and valves installed.
Lift old one off and install new one and you're good to go.
LANDROVER DISCOVERY 300 tdi CYLINDER HEAD BUILT UP NEW WITH GASKETS-LDF500180COM | eBay
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old February 2nd, 2016, 02:10 PM
If you are looking for a deal, just Google the part number...
£235.00
LDF500180 | Cylinder Head - New Style - 300TDI - Paddock Spares
Not sure it is worth buying from a source that may not be OEM
Old February 2nd, 2016, 02:24 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Thats not a bad price for a bare cylinder head.
I think....think,mine was made in Spain as is a lot of replacement Td5 heads these days.
(Mine has been worked hard....used a lot for bringing in wood thus getting stuck in mud here and there. No sign of any problems to date)
I'd use the same supplier if I had to do another change.
Al the best
Old February 14th, 2016, 10:12 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
I took a few pictures of the head I mentioned,I know I'm a nerd..........for info.
Old February 14th, 2016, 01:35 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Curious to know how these head kit suppliers know which thickness head gasket your engine needs? Guess they just supply the thickest. Which may not be the optimum choice.
Eric.
Old February 14th, 2016, 01:45 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
For mine it was a 3 hole which was what was on it. You'll see what you have if you check along the gasket at the cylinder block.
Old February 14th, 2016, 04:34 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Eric.
FYI, It's not the head that dictates the gasket thickness it's the piston protrusion from the bore that determines the thickness.
Piston protrusion should not exceed 0,8mm
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
300tdi, tdi
Wanted- 300tdi complete cylinder head J. Pound Wanted 5 March 22nd, 2015 12:35 PM
Needed: 300tdi Rocker assmebly and cylinder head. Alaskaptain Wanted 1 January 31st, 2015 02:47 PM
300tdi Cylinder Head JPRO576 For Sale - Parts 0 November 13th, 2013 04:33 PM
Cylinder head bosch with seconday air budz For Sale - Parts 2 June 23rd, 2009 04:31 AM
Southwest Rovers Cylinder Head chris snell Misc. Chit-Chat 1 August 21st, 2007 10:31 AM
