300tdi crank bolt removal method... - Page 2 - Defender Source
Old November 16th, 2011, 10:09 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Doug that is exactly the tool I am talking about. Take the pulley out and bolt this on. The engine is lock and you will be able to break the crank bolt free..
Old November 16th, 2011, 10:13 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I really dont see what the problem with using the starter is. I have done it a couple times with no problem... you just have to be careful.
Old November 21st, 2011, 06:20 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
That is fine if a little half arsed, but is no help (as Ren pointed out) when you need to tighten the bolt at which point the correct tool will be a huge help.
Matt Browne
Old October 2nd, 2012, 01:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Is there any way to put the 199 fp on this bolt during re-assembly without the special tool ?
- Charles Eames
Old October 2nd, 2012, 01:53 PM
Naplm00
Matthew
truck in gear, park brake on...go to town
Old October 2nd, 2012, 02:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Have you done it ? feels like it won't hold.
- Charles Eames
Old October 2nd, 2012, 02:59 PM
Naplm00
Matthew
that how i did it on my 200tdi. with a 4 foot bar on the ratchet.
Old October 2nd, 2012, 03:22 PM
That is the same output as the engine.... Why should it not work? Obviously put it in a HIGH gear....
Old October 2nd, 2012, 03:42 PM
Originally Posted by 130Tdi View Post
Jason we are talking about an 18 inch long big hunk of steel. What you have is the puller for the crank pulley as well as the rear flywheel lock for changing the belt.
Doug, you starting up a special tools rental company? If so, I'd like to be first in line!
On a side note, since you are coming to URE, can you bring a flywheel locking tool pleeez? I really want to see if the standard 300 TDI tool will fit the 2.8 crank? It does in theory, but want to confirm before I buy a kit. I am due for a belt change.
Mark Kellgren
KM4BOR
Old October 2nd, 2012, 06:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
did mine with engine out of the truck. what happened that you are changing that belt again already ?
Breaker bar with socket- put breaker bar against frame rail and bump the starter
Yep, that's my preferred method, get a 3/4" drive though.
Mike Hammond
Old October 3rd, 2012, 01:42 AM
Michael
Michael
Discovery 1998
Im in on the rental too, or maybe a community one that just floats around.
Old October 3rd, 2012, 02:05 PM
mikeslandrover
Mike Hammond
Oh and disconnect the stop solenoid wire on the injection pump so the engine won't run, no-one mentioned that little important step.
Mike Hammond
300tdi, tdi
300tdi crank and cam oil seals Shearpin Defender Technical Discussions 6 May 25th, 2011 09:45 AM
Removing crank gear 300tdi D90user Defender Technical Discussions 6 November 2nd, 2010 12:09 AM
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
