300tdi - correct battery group - Defender Source
Old November 24th, 2011, 01:17 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
my last 100 w/ 200tdi had a 650 cold-cranking amps (CCA) battery which was more than adequate. I don't rememer the "group" or type, but it worked well.
my new 110 has a 300tdi which arrived from its long overseas journey with an anemic 550-CCA lead-acid battery that has several dead cells (only outputting 268 CCA accordingto the test equipment).
Okay, so a new battery it is.
I just want a standard battery that will get me through the cold new england mornings. Will consider double Optimas later when I get more bling hooked up, but for right now that would be a bit of overkill.
The problem I have is (I'm sure many of you have the same issue) is that when you walk into Sears, Pep Boys etc. and are looking for a battery, the pimple-faced shithead behind the counter starts the same standard dialogue...."what year, make and model?" which inevitabely turns his universe off it's axis when he learns that the all-knowing computor suggests that such a vehicle doesn't exist.
In my case, I have a 1986 110 with newer 300tdi and many other part variations.
If I simply knew what battery specifications or group, maybe that would help wipe the smug look off his face and he may put down his happy-meal and help me get a fucking battery!
So, simply put, what is the appropriate amperage and/or battery group for a ROW Defender with a 300tdi?
I left Auto Zone completely frustrated and went to Sears and bought a Champion-brand (which is probably made by Exide anyway) with 850 CCA with the terminals in the correct position. I haven't installed it yet, but may return it based on any better suggestions here. I don't think I could do any damage with more amps, but if there is insufficient amps I know that would hurt the starter motor.
Old November 24th, 2011, 08:14 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Exide makes good batteries, but honestly, I'd go to Sears and get a Diehard Platinum. The biggest one that will fit (dimensions are on the Sears website). You shouldn't need another battery (unless you'll have really high loads) for many years.
The 300Tdi starter can draw up to 600amps in really cold weather so a 1/0 battery to starter cable would be a worthwhile upgrade.
And no, you could have a 1m amp battery and the starter won't draw any more than it needs.
10 years ago I considered Optima, but went with the better Exide spiral cell. Today, well in '09 when I bought a Platinum, I wouldn't even consider an Optima because of all the bad reports since they got bought by Interstate or Johnson (I can't remember which) and moved their plants to Mexico.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2011, 08:18 AM
bossman429's Avatar
bossman429
Adrian
1988 90
850 CCA would start a bulldozer
Most automotive batteries are Group 26 (sometimes theres a letter after it but it doesn't matter)
Id say what you have will get the job done very well.
Your starter is protected by a fuse, you wont damage it as long as its fused correctly.
------ Follow up post added November 24th, 2011 08:22 AM ------
Slightly un true - if theres a short, or a siezed starter yes it can draw alot more than its typical full load amps (FLA) or draw its locked rotor amps for a longer than typical period of time (usually about 6x the FLA)
Key is fusing it at the correct amperages so you dont light the wires on fire. (the whole point of overcurrent protection is to protect the wiring, not the loads necessarily).
Old November 24th, 2011, 08:34 AM
Naplm00
Matthew
I have the Sears pm1 marine battery. It is 1150 cca and a beast
Dual top terminals. It is the largest single batt you can fit and worth every penny
http%3A%2F%2Fwww.sears.com%2Fdiehard-marine-battery-platinum-pm-1-group-size-31m%2Fp-02850131000P&ei=gUfOTvm_E8ja0QGgs6AL&usg=AFQjCNGEO q2mvWftcm8ptBj_beKv0e2Arw
Old November 24th, 2011, 10:01 AM
With batteries, it's not size so much as weight. Weight means more lead which means more reserve. There are two kinds of battery, starting and deep cycle. The start battery is like a sprinter, gives a burst of energy for a short period but has no staying power. The deep cycle has more lead so that you have a much longer reserve, it's a marathon runner. If you run a lot of accessories or a winch you definitely want a deep cycle battery.
Buying quality is your best option. Look for Deka, Trojan, or Odyssey. Highly recommend the AGM type.
Old November 24th, 2011, 10:04 AM
Jackie Treehorn
A
1985 (legitimately)
Thanks guys
I'm going to consider the Sears marine battery actually. I haven't installed the Champion battery yet.
Also I heard good things about the Sears gel-cell batteries.
BTW, I've definately have 1-guage wire running from the battery. It's nearly a 1/2" in diameter and you can barely bend it!
Old November 24th, 2011, 10:06 AM
I'd go to Sears and get a Diehard Platinum. ... I wouldn't even consider an Optima because of all the bad reports since they got bought by Interstate or Johnson (I can't remember which) and moved their plants to Mexico.
X2. I have dual yellow top Optimas. My aux battery is already losing load after a few years. When it dies, I'm getting Sears Diehard Platinum.
Old November 24th, 2011, 10:32 AM
It is? Where is that fuse? It must be a pretty big one, wonder where they hid it.
BTW the letters usually refer to the post configuration, which is important if you don't have 12" of slack in your battery cables.
Old November 24th, 2011, 11:46 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I use the same battery that goes in my 1985 BMW 524td. The 524 has a 6 cyl engine & 2.4 displacement. I buy it at AutoZone. It's a 49-DL with 850CCA. Two year free replacement, 7 years pro-rated. Costs about $100. I've had good success with them
Old November 24th, 2011, 11:55 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I was talking normally. If you're going to talk failures all bets are off and if there's an internal short the starter is already messed up. A large amperage battery didn't cause it, which is what I think he was asking. In any case, that short would "need" all the amperage it could get.
I've never seen a fused starter cable on a Land Rover and in 35 years of fiddling with them never needed one.
I'm sure you and most people know, but the Diehard Platinums are Odyssey batteries.
To be clear, #1 is not the same as 1/0.
At a 600amp draw, which of course isn't the norm, #1 is barely adequate giving you about a 0.5v volt drop. 1/0 would be 0.4v. 2/0 would be 0.3v
Once I move further north, hopefully next year, I'll be installing a 2/0 starter cable.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2011, 05:45 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok let me restate. Most vehiclee have fuses for the starter. I forgot we were dealing with british electrics here. Im surprised they didnt use pennies between the fuse clips in these trucks
Either way. The battery u have is fine
Old November 24th, 2011, 07:53 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I have never seen a fuse for the main starting circuit on any car. Not saying they are not out there, but the following cars I have owned have not had fuses:
2005 Avalanche
2003 Siverado SS
2005 VW GTI
1992 Jetta Diesel
1989 Mustang
1984 Rabbit GTI
1984 Jetta Diesel
1968 Camaro
1966 El Camino
1965 Nova
1964 Chevelle
plus some others
and my 86 Defender.
I went with the Optima. I can look for the group size when I get home, but I went with the largest one they make that is just a top post.
I also replaced the cables with 2 gauge cables. Some will say that by doing that you risk burning the cables up if the starter solenoid sticks on, but I prefer a higher current capacity and lower resistance during cranking.
Also, other than speciality battery companies like Braille, all the batteries are made by the same two companies. The "Powersport" battery I bought at Autozone is the same as the factory battery in my Harley, except it is grey instead of black, missing the Bar and Shield, and didn't cost an extra $80.
Just look at the specs for CCA (bigger is better) and what will physically fit your car.
-Best of luck!
Old November 24th, 2011, 08:10 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Can you provide a link to some?
I wouldn't consider Exide to be a specialty battery company. I wouldn't even consider Odyssey or Deka to be.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2011, 08:26 PM
2 gauge??? That is a very small cable for a starter.
Old November 24th, 2011, 08:27 PM
red64chevelle
Daniel Smith
So, Braille is made by them? Damn, GNB and Exide are one now. So besides them, who is left in the US? We have had to change out Submarine batteries to a new glass mat design due to GNB/Exide deciding to get out of the business. No more flooded Lead/Acid batteries for us.
Most companies moved off-shore due to the EPA regs on lead and acid. We don't have any problems with people south of the US dying of lead poisoning, but god forbid they do it in the US.
------ Follow up post added November 24th, 2011 08:42 PM ------
Yep, it is over 1/4" thick, and can carry about 250 amps. It is often used as a grounding lead on Arc welders. The factory cable looked to be about a 4 or 6 gauge.
Old November 24th, 2011, 09:56 PM
Show me! I don't believe it. I just checked my factory cable and it is 1/0. You are not starting a truck with 4 or 6 gauge.
Old November 24th, 2011, 10:10 PM
Antichrist's Avatar
Antichrist
Tom Rowe
As of just a very few years ago Exide made their own batteries and at least their AGM's were made in the US. I haven't checked lately.
I don't mean that Braille is made by Exide, I was just saying Exide was mfg.
The carry capacity is determined by the voltage and length of the run, you can't just say "250 amps".
#2 wouldn't do too well on a welder if you're running 250amps.
For petrol engines #2 should be ok (depending on what the 2.25/2.5 starters draw, I can't remember).
Not for diesels though.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2011, 11:49 PM
bossman429's Avatar
bossman429
Adrian
1988 90
2005 Avalanche
2003 Siverado SS
2005 VW GTI
1992 Jetta Diesel
1989 Mustang
1984 Rabbit GTI
1984 Jetta Diesel
1968 Camaro
1966 El Camino
1965 Nova
1964 Chevelle
plus some others
and my 86 Defender.
Pontiac G6, My mustang??? i guess its not as common as I thought though after doing a little search.
Typically it wil be a 30 or 40 amp fuse.
30A @ 12vDC is 360w
360W is about 1/2 hp Which is your typical petrol motor starter. I'd imagine a diesel would be higher due to compression
Almost all overcurrent protection devices (fuses and circuit breakers) allow for motor inrush (~6x Full load amps) for a short period of time (anywhere from 1/4 - a couple secs depending on the time curves). Often this trip curve is adjustable either by the magnetic or instantaneous setting on a c/b, or by the characterstics of the fuse element (time delay). Therefore you could pull 100A through a 30A fuse for a very short period of time before it blows.
Heat is a result of resistance encountered of current flowing through a conductor. If the wire is too small for the amount of current being allowed to travel through it by the upstream overcurrent protection device, it will over heat and possibly risk fire. This is how fuses work. If you have 50A running through a 30A fuse, over time the fuse element will heat up and then melt, breaking the flow of current. This is why it is always important to protect your wiring with the proper fuse or cicuit breaker. You want the element in the fuse to melt, NOT YOUR WIRING!. You can always run larger than necessary wiring, but not the opposite.
As far voltage drop, running a larger than necessary cable for such a short distance (like between your battery and starter) is totally useless. You're only going to see voltage drop over long distances as the resitance builds up. (I'm talking hundreds of feet here).
now - what was the question? or yea I'm sure battery is just fine
Old November 25th, 2011, 08:05 AM
I put an Interstate mtp34 in my 300tdi 110 because that's what we have at the dealership. On a cold morning when I use the glow plugs it is slow to crank, but it always starts, so far at least. I'll probably add a block heater this winter.
Old November 25th, 2011, 09:14 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Bossman, You're confusing the relay circuit with the motor circuit.
You're not going to have a 29amp starter, which is what 360 watts @ 12v is.
The Pontiac PG260 starter has a 1.4kw motor which is a bit over 116amps @ 12v. That's not going to be fused at 40amps.
Volt drop is typically measured per foot and every foot is going to induce voltage drop. It's a measurable increase as the distance increases and/or as the cable size decreases. At 116amps the overall volt drop is .12v for #2 @ 5'. It's .23v at 10'.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
300tdi, battery, tdi
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
