300tdi - correct battery group - Page 2 - Defender Source
Old November 25th, 2011, 01:31 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by Antichrist View Post
Bossman, You're confusing the relay circuit with the motor circuit.
You're not going to have a 29amp starter, which is what 360 watts @ 12v is.
The Pontiac PG260 starter has a 1.4kw motor which is a bit over 116amps @ 12v. That's not going to be fused at 40amps.
Volt drop is typically measured per foot and every foot is going to induce voltage drop. It's a measurable increase as the distance increases and/or as the cable size decreases. At 116amps the overall volt drop is .12v for #2 @ 5'. It's .23v at 10'.
I think I ate too much turkey last night.
I stand admittantly corrected.
Old November 25th, 2011, 07:23 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
My god, now this is what I call a technical discussion!
For my 300Tdi I have always just tried to put in the biggest CCA battery that I can buy. For New England winters I am sure your 850 CCA will be fine. Having said that I like the sound of that Sears marine battery ...
Cheers
Old November 25th, 2011, 09:37 PM
CCAs are a pretty misleading method of judging battery performance/capability. The better numbers to look for are reserve capacity ( in minutes) at the 20 amp rate.
950 CCAs are not much good if you only get 60 seconds of them.
Old November 26th, 2011, 08:36 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
In case anyone is interested, this morning someone sent me a test report on their 300Tdi starter which certified it was within spec.
Max current draw was 731amps.
Median current draw was 457amps.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
300tdi, battery, tdi
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
