300tdi coolant problem - Defender Source
Old April 17th, 2012, 11:05 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
New:
radiator
check valve
thermostat
p gasket
thermostat housing gasket to head
gasket on thermostat u
water pump
pushes all coolant into resovoir hits 220 I shut it off before I use an electric cooling fan and clutch fan all are in good condition the electric fan is on a swithc not a sensor.
any ideas????????
No moisture in exhast pipes
No mix of oil and coolant on radiator side or oil side.
Old April 18th, 2012, 07:03 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Is the system over pressurizing? What is the mileage on the engine, head etc. Are you loosing coolant? I would replace the Thermostat. Some new less expensive brands have been bad. Easy to check what you have off the truck however. Are you certain that the gauge is not at fault?
Land Rover 110
Old April 18th, 2012, 08:16 AM
yes. need more information. I have finally cracked my cooling problems with my 2.8. could easily just be gauge. what are the driving conditions that you overtemp?
Old April 18th, 2012, 12:32 PM
323jamie's Avatar
323jamie
jamie
The system is overpressurized I removed the thermostat to see if it was that. It still overpressurized. I disconnected the heater core and bypassed it and it continued. I added a gage to in the thermostat housing and when it reached 210 it would spew through the cap. I was suggested a carbon test to see if its a blown gasket.
Old April 18th, 2012, 12:39 PM
that's my guess. escaping exhaust gases leaking into coolant is the most likely culprit for a pressurized blowout.
Old April 18th, 2012, 01:31 PM
323jamie's Avatar
323jamie
jamie
hmmm does anyone know of an exhaust test?
Old April 18th, 2012, 01:43 PM
go to napa and you can get a sniffer kit for about $30-$40. there's a good youtube on using it as well by trailfitter.
it's not a absolute test. there's a risk of false negative. it uses a fluid that changes color when it detects exhaust in the coolant gases. if you are being pressurized though, it should give you a good reading. there are some gasket leaks that do not lead to exhaust gases in the coolant, which yields the false positives.
Old April 18th, 2012, 01:57 PM
323jamie's Avatar
323jamie
jamie
i will check that out
Old April 18th, 2012, 04:24 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
That. Been there, done that.
Old April 18th, 2012, 09:02 PM
Capt Milks's Avatar
Capt Milks
That was my first thought too but I didn't want to be too negative. I have seen that on several trucks.
Land Rover 110
Old April 19th, 2012, 12:25 AM
323jamie's Avatar
323jamie
jamie
I am trying to discover what type of gaske I have and supplies needed. bolts gaskets
Old April 19th, 2012, 01:19 AM
paluskat
Tom Paluska
D110 200TDI
While on the subject...
Since this thread is going, wondering if anyone has a suggestion for me.
I have a 200tdi that only recently started having problems with increased temps. In the past it ran at about 190. I have a new vdo guage. New thermostats x 3 temporarily fix the problem then it starts again. When this happens, temps seem to go down temporarily when rpms are up then increase while coasting/neutral. Take the thermostat out, it runs at about 110F and temp never goes up no matter the load. Could the thermostats be that bad/ unreliable? Or am I missing something? Radiator is new.
Tom
Old April 19th, 2012, 07:36 AM
Do not take the thermostat out ever!
Old April 20th, 2012, 12:00 AM
paluskat
Tom Paluska
D110 200TDI
Just for a test only.
Old April 20th, 2012, 09:35 AM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I had similar problems with my 200Tdi. I tested with the NAPA sniffer and got negative results, but I could see bubbles coming up through the coolant in the reservoir. New head gasket cured the problem.
John Karlsson
Hope Valley, RI
Old April 22nd, 2012, 08:43 PM
Capt Milks's Avatar
Capt Milks
If you look on the right side of the motor you can see what type of head gasket you have. The gaskets are marked with holes, or no holes to designate the thickness of the gasket. Look right below the head and you will see a portion of the gasket protruding beyond the block. This will be the section to look for the holes. The gasket thickness is determined by the piston protrusion. You will also need a set of head bolts. While you are at it I would also get a bolt set for the intake and exhaust. I would also highly recommend to have the head checked before you put it back on to make sure it isn't warped or cracked.
Land Rover 110
Old April 23rd, 2012, 01:39 PM
323jamie's Avatar
323jamie
jamie
its a 3 hole.
head bolts paticular brand? or place to order
British Pacific for parts are they reputable?
Old April 24th, 2012, 08:24 PM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
Check Turner Engineering. They ship to US quickly.
Old April 24th, 2012, 08:46 PM
Lee
Lee O
95 NAS D-90 300Tdi
+1 on Turner. Head bolts are reasonable too.
Old April 25th, 2012, 12:21 AM
323jamie's Avatar
323jamie
jamie
Thanks a bunch on this.
I just conducted the exhuast gas temp check and the fluid stayed the purple.
After reconsidering my trouble shooting I think its a clogged or blocked injector which if you read the service manual its states overheating can be caused by a block injector. This is simple way to check the injectors.
300tdi, coolant, tdi
300Tdi locating coolant temp sensor? crown14 Defender Technical Discussions 10 February 22nd, 2017 05:10 PM
What is the correct type of coolant for a 300tdi? Manimal Defender Technical Discussions 10 December 25th, 2011 03:02 PM
Leaking coolant problem Cred Defender Technical Discussions 6 November 22nd, 2010 09:17 AM
300tdi Coolant Leak Lee Defender Technical Discussions 10 April 22nd, 2009 10:46 PM
