300tdi coolant problem - Page 2 - Defender Source
Old April 25th, 2012, 07:10 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by Lee View Post
+1 on Turner. Head bolts are reasonable too.
? did you have to do yours again.
BTW, the head bolts are reusable up to like 5 times.
The exhaust gas "sniffers" don't always work very well with diesels. Of the countless tdi head gaskets I change it is rare that the test actually shows evidence of exhaust, yet 100% of the pressurized systems have been cured with a head gasket.......other than those that needed a new head also from excessive overheating (I have not had any long term success "skimming" tdi heads).
Matt Browne
Old April 25th, 2012, 08:21 AM
If it's overheating, there's about a dozen reasons. If it's overheating and a pressurized blowout, change the gasket. I can't think of anything else it could be. First time I did mine, I was still new to diesels and highly intimidated. Now I realize how simple changing that gasket is, and it doesn't take all that long either. watch the youtube trailfitter videos first if you want to visualize it.
You will gain so much confidence in your engine and abilities by having changed the gasket yourself at least once.
M&D told me my bolts were good up to 3 times, but you have to measure them to make sure they have not stretched. if they did, then replace. Last time I did my head I ordered all new bolts, but I had already used mine once and didn't want to be delayed in case one had stretched on disassembly waiting on additional bolts. If you order all new bolts, then when you pull the old ones out, you can measure them. if they are to spec, then you have spares for the next time.
Old April 25th, 2012, 05:11 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
I am going to check my diesel injectors for fluid spray. I ordered a compression test kit 0-1000psi and then I will procede to check psi before I disasemble the motor.
I thank you two above those pieces of knowlegde you have boosted my confidence in the repair.
I have rebuilt a couple of bmw motors and several head gaskets. but these symptoms were in plain view.
Old April 26th, 2012, 03:36 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
99% sure it'll be the head gasket.
Mike Hammond
Old April 26th, 2012, 04:17 PM
Just change the head gasket. It is VERY simple and takes no time...
Old April 26th, 2012, 04:56 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
I second the last two posts. Easy job, and 99.9999% sure it is the issue.
300tdi, coolant, tdi
300Tdi locating coolant temp sensor? crown14 Defender Technical Discussions 10 February 22nd, 2017 05:10 PM
What is the correct type of coolant for a 300tdi? Manimal Defender Technical Discussions 10 December 25th, 2011 03:02 PM
Leaking coolant problem Cred Defender Technical Discussions 6 November 22nd, 2010 09:17 AM
300tdi Coolant Leak Lee Defender Technical Discussions 10 April 22nd, 2009 10:46 PM
