300tdi Coolant Leak - Defender Source
Old April 17th, 2009, 06:32 AM
Lee
Lee O
95 NAS D-90 300Tdi
300tdi Coolant Leak
I've got a coolant leak in my 300tdi (95 NAS D-90), and for the life of me can't find it. No puddles or anything, but I can smell it after driving and need to add coolant approx once a week.
There's no oily mist on my windshield when I run the heater and the oil looks fine.
Thanks for any thoughts.
-Lee
Old April 17th, 2009, 07:52 AM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
Pressure test? Not too familiar with the 300TDi, but that should be a reasonable place to start.
Old April 17th, 2009, 08:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
where do you smell it? the exhaust or under the hood?
Legend in My Own Mind.
Old April 17th, 2009, 11:46 AM
discotdi
Todd Miller
Land Rover
how about the "p" gasket i think between block and front cover. they are suppose to be notorious for leaking and hard to see.
Old April 17th, 2009, 12:36 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Any smell in the cab? Might be a small leak in the heater core.
Dennis
Old April 17th, 2009, 01:58 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I've got a similar problem, a tiny (a few drops) only in the driveway. It drips off the right side bellhousing bracket, can't be the heater core it's RHD. I smell it occasionally.
Keith
Big, Red and ... aaa Red..
Old April 17th, 2009, 05:40 PM
discotdi
Todd Miller
Land Rover
Land Rover 300 TDi Water Pump 'P' Gasket
This is the gasket that fits behind the water pump on all Land Rover 300TDi engines and is commonly known as the 'P' gasket.
It is common for this gasket to fail causing a slight weep at first of coolant down the engine block, behind the alternator.
Old April 17th, 2009, 09:13 PM
Lee
Lee O
95 NAS D-90 300Tdi
I smell it when I get out of the cab and in the engine bay. I never smell it in the cab. I'll check the P gasket. Thanks for your help!
Old April 20th, 2009, 10:28 AM
66rover99's Avatar
66rover99
Dave Blair
66-88 95-110 99-100
Might also try another radiator cap. I had a similar leak on a feshly rebuilt 200tdi, only showing a few drops on the driveway each morning.
A local indy Land Rover mechanic said to check the plastic screw-on rad cap. He said he's seen a number that didn't release pressure until over 30 psi, which caused slight weeping from either the head gasket or through various other gaskets, like the P gasket. I put a different cap on mine and immediately the problem stopped, and within a couple of days any signs of wetness disappeared. My fingers are still crossed, but so far I think that's beat the problem.
I'd try an new cap before going to a lot more effort. Good luck.
Dave
Old April 20th, 2009, 08:56 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Lee, you'll usually see coolant on top of the front axle on the driver side.
The gasket goes right here
ID:	18880   Click image for larger version
Matt Browne
Old April 22nd, 2009, 10:46 PM
Lee
Lee O
95 NAS D-90 300Tdi
Bingo! Looks like it's the water pump gasket.
Easy job?
Thanks for your help guys!
-Lee
300tdi, coolant, tdi
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
