300TDi Boost Gauge sender in manifold - Page 2 - Defender Source
Old June 16th, 2014, 10:49 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Originally Posted by chris snell View Post
Nice...but don't most of the dash cluster wires run through the two (three?) little plugs behind the dash?
I'm mounting the EGT and boost gauges in the center of the dash (to the left/right of the clock) because there were already 2-1/8 holes already cut when I removed the plate. Until I decide to upgrade to the MudUK center console, these gauges will be in the center of the dash. So, that's why the sending wires/line are where they are (if that's what you were asking about).
Old August 22nd, 2016, 01:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Originally Posted by Jackie Treehorn View Post
Posting from iPhone, so only one picture at a time.
Here is what's going on at the back of the manifold now....
Where did you end up getting your fittings? I am looking to do this and would love to just order it all at once.
300tdi, boost, tdi
Oil gauge and sender upgrade question Rover110 Defender Technical Discussions 4 March 30th, 2013 02:17 PM
sender P/N for factory oil pressure gauge 300TDi TS888 Defender Technical Discussions 4 May 28th, 2011 05:56 AM
300tdi Temp Sender Plug TDI Guy Defender Technical Discussions 3 April 19th, 2009 07:02 PM
300tdi temp sender thread?? D90user Defender Technical Discussions 2 March 16th, 2007 02:11 AM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 06:47 AM
