300TDI Black Smoke on startup - Defender Source
Old July 13th, 2010, 11:55 AM
drv2fst
Kirk
Defender
I have a relatively new (<5000 miles) 300tdi. It puffs a cloud of black smoke every time I start it. Is this normal? Is there any way to reduce or eliminate it?
Old July 13th, 2010, 12:43 PM
Best4x4's Avatar
Best4x4
Kelly Graham
P38
My truck does it too Kirk.... but I based my truck as being "normal" off of yours. Blind chasing the blind...
Old July 13th, 2010, 12:47 PM
drv2fst
Kirk
Defender
I see it all the time in other diesels but wonder if it can be "fixed".
Old July 13th, 2010, 01:39 PM
GreenRover's Avatar
GreenRover
Frank S
1984 D90
From what I understand, this is fairly normal. My 300tdi gives off a small puff when started as well. I believe that it is caused by unclean / dirty / old injectors. I may be wrong. You could try running some injector cleaner through the system. If not there is no way to clean / rebuild them by removing them without specialized equipment, as you can do with some other diesels. Only thing u'd be able to do is replace. Search here a little and you'll see a bunch of good threads on the topic. Also as I mentioned, I'm a total noob, so my info may not be 100% accurate.
Old July 13th, 2010, 01:46 PM
drv2fst
Kirk
Defender
This is a NEW engine. My injectors should be in good shape.
Old July 13th, 2010, 02:11 PM
Mine does it too.
Old July 13th, 2010, 03:06 PM
GreenRover's Avatar
GreenRover
Frank S
1984 D90
I think I remember reading something about small amounts of residual fuel being burned off the injectors upon ignition causing the puff of smoke. And the only way to help stop it was clean / new injectors. Again I may be wrong. So the fact that your engine is new makes me wonder. Is it truly a brand NEW engine? Or is it a rebuilt setup? Is there any possibility that there are some used / non-new parts in it? In any case from what I understand as long as it isn't smoking constantly or when it's under load it's perfectly normal and nothing to worry about.
Old July 13th, 2010, 03:27 PM
drv2fst
Kirk
Defender
It's an entirely new engine. Not a rebuild. The engine has less than 5k miles total since new.
Old July 13th, 2010, 04:26 PM
berti1554
Robert Klima
84/110
All 300tdi's puff out a black cloud every time you start them. They do it even when they are new. Maybe it's caused by the design of the injection system or something else. I'm not sure about but will ask a tdi-specialist over here...
Old July 13th, 2010, 05:04 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It's a feature of the engine, 200tdi's do it too.
Mike Hammond
Old July 13th, 2010, 05:25 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I think it's along the lines of the excess fuel for cold starting (or just for "starting" in general)
I've driven ones that hardly smoked at all at startup, but their fuelling was wound back so much, there was bugger all power when you drove (to the extent that if you gunned it then just lifted off the gas, the engine would cut out!) a quick turn or so on the fuelling screw soon sorted that little gremlin out.
Old July 13th, 2010, 05:46 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
mine certainly does. Like a tractor or tug boat. Just lovely in the garage every morning.
Old July 13th, 2010, 06:20 PM
What was the line from Apocolypse now ? "I love the smell of diesel(napom) in the morning"
All of the Tdi's I have been intimate with smoked a puff on cold startup....
Old July 13th, 2010, 06:24 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Mine also does it since new, 5 years now. Adjusting the valve clearance won't make any difference on that issue. It's definitely a feature .
- Charles Eames
Old July 13th, 2010, 07:26 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mine always have. Even with new injectors. Looks like that's just the way this engine is. I've adjusted the smoke screw but it doesn't make much of a difference.
Old July 13th, 2010, 07:53 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Mine always did it too. It is a diesel after all so, par for the course I think......
Old July 13th, 2010, 10:53 PM
discotdi
Todd Miller
Land Rover
if you don't like it, I may be able to live with it and will take it off your hands, just pm me.
Old July 13th, 2010, 11:10 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
it's a feature so you know it started okay...
actually mine doesn't do it at all... I don't know what y'alls problem is...
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Normal
Keith
Big, Red and ... aaa Red..
Old July 13th, 2010, 11:22 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Just like any human smoker. Gotta take that first big puff and exhale as soon they get started.
legend in my own mind
300tdi, ac, start, tdi
200tdi massive black smoke on .. Rugbier Defender Technical Discussions 36 May 1st, 2017 07:54 AM
300tdi smoke at neutral throttle D90user Defender Technical Discussions 57 December 4th, 2009 11:54 AM
Puffs of black smoke devinchi Defender Technical Discussions 10 December 31st, 2008 09:05 AM
