300tdi belt tensioner came off! - Defender Source
Old September 22nd, 2013, 07:52 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
So while on a trip the bolt/stud holding the belt tensioner to the front of the engine (300tdi water pump housing/bracket actually) pulled out, which in turn shredded the belt. When I examined the bolt I learned that it had previously been helicoiled and it pulled the threads out when the bolt came loose...
Anyone had this happen before and repaired it successfully? Any suggestions?
Frank
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old September 22nd, 2013, 08:35 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Mine had been previously helicoiled (and not well), so I went up on size and loaded it up with lock tight red just in case. Works fine. Much better than the alternative of replacing the entire cover.
The fact that yours suffered a violent ending may make repairing with a second helicoil less successful.
I would imagine that stud simply ripped right out of the hole if the entire tensioner fell off.
It's soft material your working with so be careful and unless you plan on removing the radiator and perhaps the entire breakfast, you need a compact right-angle drill, so keep that in mind when you're planning your attack.
Good luck
I think it's time for a new timing cover
Mark Kellgren
KM4BOR
Old September 22nd, 2013, 08:42 PM
Mtanzania
Frank
And they are so reasonably priced
------ Follow up post added September 22nd, 2013 07:49 PM ------
I placed another helicoil in the hole after recutting the threads with a small amount of jb weld which allowed me to get it off the highway and to a radiator shop (ended up needing a radiator as well when the pressure build up caused a leak) but not sure it will get me home (3+hours) repaired the way it is... guess I'll find outnon our way back north. Thankfully my wife was very understanding as she does not really get the whole 'rover' thing
94 D1 300tdi - Sold
Old September 22nd, 2013, 09:22 PM
Good luck. BTW, I mis-spoke. It's the water pump housing bracket, not the time cover. part no ERR3736. RDS has them for $425.
Here is a used one in the UK on ebay.co.uk for under $100 and they ship to US.
http://www.ebay.co.uk/itm/Land-Rover...item4176fa9cde
Mark Kellgren
KM4BOR
Old September 22nd, 2013, 09:25 PM
Mtanzania
Frank
Thanks. I was just hunting for one... I'm a bit leary of a used one!
94 D1 300tdi - Sold
Old September 22nd, 2013, 10:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
A machine shop could weld up the hole and re-drill & tap the threads,
RDavisinVA
Old September 22nd, 2013, 10:35 PM
atlcruiser
david
many
If you are stuck call me or e mail first thing. I can fed ex you one then we can sort the replacement later.
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
Old September 22nd, 2013, 10:41 PM
Mtanzania
Frank
This is what I was thinking...hopefully make it home and get it off for the THIRD TIME. tired of ordering p gaskets and water pump gaskets lol.
------ Follow up post added September 22nd, 2013 09:45 PM ------
David,
Thank you very much for the offer! I had to rent a car as we were on our way for a family vacation so I am currently not driving it. I will be heading home next Saturday and Sunday and will have about 3-4 hours that I am going to try and limp it home. If I don't make it, I will have to contact you.
Thanks again,
Frank
94 D1 300tdi - Sold
300tdi, tdi
300TDI Timing Belt Tensioner Viton For Sale - Parts 1 September 2nd, 2011 10:31 AM
300TDI serpentine belt tensioner bearing R&R Viton Defender Technical Discussions 3 August 31st, 2011 09:15 PM
300tdi timing belt tensioner Viton Defender Technical Discussions 4 August 14th, 2011 10:03 AM
Freelander Timing belt Tensioner mjekogian For Sale - Parts 0 August 11th, 2010 12:44 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
