300tdi bellhousing sealant??? - Defender Source
Old November 7th, 2015, 12:40 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Quick question I'm just about to bolt my r380 transmission back to the 300tdi engine and I'm curious if I need sealant between the bell housing and the flywheel housing. The workshop manuals says to use it when applicable.... What to do?
Old November 7th, 2015, 12:42 PM
If you ever need to separate the two you will wish you didn't use any sealant. Just my own opinion but I don't live in snowy Canada.
Old November 7th, 2015, 12:49 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I know Ashcroft recommends no sealant between the bell housing and transmission as it can cause shift problem. I'm wondering if there are any issues created about putting on these faces.
Separating would be a pain with it in certainly.
Old November 7th, 2015, 12:52 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Don't do it!
Old November 7th, 2015, 12:59 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Why?
Old November 7th, 2015, 01:17 PM
It is helpful for keeping water out when wading but obviously makes later separation difficult. What you can do is put a little oil on one surface and that will stop the silicone sticking but still let it seal.
300tdi, tdi
WTB: R380 transmission for a 300TDI with bellhousing and shifter Mike Sandone Wanted 1 September 13th, 2011 06:51 PM
thread sealant JBOD77 Defender Technical Discussions 11 April 2nd, 2009 02:35 PM
Plenum to air intake sealant rgrrvr Defender Technical Discussions 0 June 1st, 2007 09:26 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
