300tdi and automatic? - Page 2 - Defender Source
Old May 18th, 2011, 11:19 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Jeff, i was used to a manual coupled to a 200BHp 3.9V8 so after i finished my 300tdi auto build it was a bit of a shock to have traffic pull away from me at the lights, however i am now used to it and love it.
I built mine with a standard 300tdi, 1.22 trans as the autobox was originally a disco item.
i am running on 235x85x16 tyres & found that the gearing is a little high the box shifts into top at 52mph and i can just about cruise @ 70mph @ 3000rpm
I may change the xfer box to a 1.4 defender item as this will allow the box to change into top at 45ish and allow the engine to rev past 3K, however i have now adjusted to driving a log burner just fine and 24-26Mpg dont hurt that much.
i have a build thread on here somewhere
regards all
------ Follow up post added May 18th, 2011 04:25 PM ------
BTW the "electronic" version of the 300tdi as fitted in the later disco's did have a higher output 133bhp i think using a modified pump and different injectors.
the kickdown cable is attached to a lever assy bolted to the top of the accellerator cam on the pump, easy to fit and remove.
Old May 18th, 2011, 11:49 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by crown14 View Post
I thought the difference to the injection pump was the provision for the kickdown cable.
When I bought my LR 300tdi engine conversion kit from Frog's Isl in 2001, They worked with Ashcroft to get me mated up with the 4HP22. Got down to the finish line and I needed the arm on the IP to attach the kick down cable to. Ashcroft sent it out right away, but I had to wait another week to get 'er on the road.
Old May 18th, 2011, 04:33 PM
TS888's Avatar
TS888
Tony Sims
1984 110
What happens to an auto when you crank the starter in drive? Does it inch forward like on a manual?
Nothing happens. Autobox trucks have a starter interlock so the starter will only work in N or P.
Tony
1984 110 "Smokey" (sold)
Old May 18th, 2011, 04:45 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
you can wire that out, good for off roding if you stall it but an MOT failure in the UK
you'll love the auto do it
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old May 23rd, 2011, 11:07 AM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Hi Guys! You can see pictures (and if you know spanish even read about it) of the ZF4hp22 install on my tweaked D110 300tdi. I really loved it while it worked since autobox or converter are busted now. Im back to the R380 momentarely but till I fix the auto again and will put it back in.
It was the perfect combination for off road on rocky terrain.
http://www.landroverclub.com.ar/viewtopic.php?t=116756
Regards,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old May 23rd, 2011, 02:59 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Thanks for the link!
Today I forgot to tell you my autobox arrived last week...
I'll put it away, maybe in a future...who knows!
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
300tdi, tdi
Diesel & auto in D110 artm Defender Technical Discussions 18 July 9th, 2004 04:11 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
