300tdi alternator/vacuum pump - Defender Source
Old January 13th, 2015, 04:08 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
The 300tdi vacuum pump is notorious for leaking. Mine is leaking out of the rivets and while you can drill the rivets out, clean it up and put a gasket on and bolt it back up I would still like to see if anyone has fitted the 2.8 alternator/vacuum pump to their 300tdi engine and run the vacuum from there. Would also be nice for the LHD trucks as its more direct. The only downside is I think it needs an oil line.
I was PMing with Mark (Overlander) about getting some measurements. I think it should clear the downpipe.
Would anyone have a part number reference for one of these alternators?
ebay.uk
Bosch F 000 LD0 119
Ford BG1T1 0300 BA
Maxion 74196
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 13th, 2015, 04:31 PM
ebay.uk
Bosch F 000 LD0 119
Ford BG1T1 0300 BA
Maxion 74196
I still have my old oil feed line that supports the turbo and vacuum pump so i can give you measurements on that
Mark Kellgren
KM4BOR
Old January 13th, 2015, 10:00 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I have one that I pulled off of mine that leaks that I can send you if you'd like. You can rebuild that off the vehicle then swap it in. Let me know.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old January 14th, 2015, 08:36 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks for the offer but I have mine as a spare. It was leaking a lot and will seal it back up for later
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 8th, 2015, 04:53 PM
andyrad
Andy Radlgruber
None.
My 2.8 parts catalogue calls the alternator out as 74196 (Maxion part number). It is a bosch unit (F009LD0115) and they are very expensive. Right now I think my pump is failing as something is clacking quite loudly from that immediate area.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old April 8th, 2015, 07:39 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
There is another option I have begun to look at that uses the pumping action of the steering pump to create boost for the brake system.
https://www.performanceonline.com/Hy...e-Booster-Kit/
300tdi, ac, alternator, tdi, vacuum
2.8 PS Vacuum Pump ersatzknarf For Sale - Parts 22 July 30th, 2013 10:39 AM
200tdi vacuum pump delete D90user Defender Technical Discussions 15 May 21st, 2013 01:23 PM
300tdi Vacuum Pump navydevildoc Defender Technical Discussions 9 June 30th, 2011 08:11 AM
300tdi vacuum pump D90user Defender Technical Discussions 22 April 21st, 2009 04:39 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
