300Tdi AC question - Defender Source
Old September 11th, 2006, 10:40 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
300Tdi AC question
installed an NAS AC kit this past weekend on my 300Tdi engine and have one question before I have it charged and fire it up...I jumpered the two leads going to pressure and temperature sensors on the thermostat housing (which I don't have)...plus jumpered the leads going to and from the ECU (which I don't have)...is that OK?
thanks
Old September 12th, 2006, 12:00 AM
Thats exactly what I did. I did jumper the leads such that the trinary switch still worked (pressure safeguard) but the engine temp condition is in a constant "OK" state.
Old September 12th, 2006, 01:24 PM
Gkase's Avatar
Gkase
George Kase
Jim,
So you jumpered the yellow/black and black/white leads? So this "trinary switch" (do I have one?) still works but all other AC functions also work like they're supposed to?
Old September 12th, 2006, 11:38 PM
I dont remember the colors off the top of my head, I'd have to find my notes. The trinary switch is the thing on top of the drier. It has 3 modes (duh) low pressure shut off, normal on, and overpressure shutoff. The upshot of the whole thing is that my AC wont automatically shutoff if the engine overheats, but all other functions work as they are supposed too.
Old September 13th, 2006, 11:24 AM
Gkase's Avatar
Gkase
George Kase
Aha! I got one of them...wondered what that plug was...I'm glad to hear confirmation on this. Just jumper the ECU leads and everything else works as it should...thanks Jim.
Old September 13th, 2006, 02:34 PM
btate
Bryan Tate
d90
George, thanks for the schematic for connecting my a/c to the 94.
As I don't have ECU connections I am clarifying. You are just going to tie the ECU (off the a/c wiring harness) leads together??
Old September 13th, 2006, 02:52 PM
Gkase's Avatar
Gkase
George Kase
Yes...that's exactly what I did...those two leads have a jumper placed between them. And as Jim pointed out, all will work except you'll have to watch your engine temp gauge and shut off the AC if it climbs too high...
Old September 13th, 2006, 02:58 PM
btate
Bryan Tate
d90
What about idle? I am walking a different path as I have ECU, you don't; But, I thought those two leads tell the ECU when to idle up to handle a/c load? I had read from another post that someone said the A/C pulls idle down (on a 94 d90) without these connections.
Do you think these were the original functions of the wires? This post makes it seem like it was more of a safety cutoff valve to prevent overheating....
Thank, curious as to how the bypass will work for me....
Old September 13th, 2006, 03:07 PM
Gkase's Avatar
Gkase
George Kase
perhaps someone else could take this question...I don't have a clue...sorry...
300tdi, ac, tdi
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
D110 300Tdi Rear AC unit - NEW artm For Sale - Parts 36 December 18th, 2008 09:09 AM
question about installing 300Tdi kit from M&D? Gkase Defender Technical Discussions 12 May 24th, 2006 08:36 PM
D110 300Tdi AC Compressor? Hssser Defender Technical Discussions 3 August 17th, 2005 07:47 PM
AC question Campbell Defender Technical Discussions 4 March 8th, 2004 10:30 AM
