300TDi A/C - Page 3 - Defender Source
Old March 16th, 2012, 12:14 PM
Originally Posted by michael67 View Post
Unfortunately, the reverse isn't true - the A/C does not know when the motor is running. So if you kill your engine with the A/C on, you have to shut off the A/C or you won't be able to start your engine. Three guess as to how I found out, and the first two don't count
I have had no trouble starting tdi's where the a/c was left on when the engine was shut down ?
Old March 17th, 2012, 06:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Shoot me an email if anyone is looking for a new a/c kit for a 300 tdi. Also can sell the kit without the compressor so any 200tdi guys would just need to adapt a standard belt compressor onto the engine and then just get 2 hoses made.
Legend in My Own Mind.
Old May 28th, 2012, 05:45 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
AC the way to be
Old May 28th, 2012, 10:05 PM
Gold Bug's Avatar
Gold Bug
Trace
2003 Discovery SE7 *SOLD*
I'm interested in a complete kit for a 300. Can you give me a total with shipping to 78028.
Trace
Old May 29th, 2012, 09:16 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Trace
Ditto - 98335
Old September 20th, 2013, 11:56 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
AC
Digging up old post, did anybody get any information on this?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 16th, 2014, 06:07 PM
the rover shop
shayne young
I forgot about this thread.. I think I will try this kit this week or next..
Old September 4th, 2014, 03:24 PM
bluenosers1
bruce
td5 110
AC kit
Hi folks, new to the forum and relatively new to land rovers..
Anybody try this kit on a TD5?
Any idea how this kit affects the normal heat ducts?
Is there room for the speakers to go back in?
Old March 17th, 2017, 10:58 PM
sushihaus
james
none
Does the Nostalgic Air under dash unit for the Chevy interfere with the heater vents?
Old March 18th, 2017, 02:16 AM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Yes. The passenger side will be completely covered up, the driver side will not. Given the limited output of those heater vents you can just redirect to windshield though.
Old March 22nd, 2017, 11:55 AM
sushihaus
james
none
Hi Piekas,
I'm trying to put your kit together and looking at the Nostalgic Air website. Can you point me in the right direction on a couple pieces on your list? Some names have changed.
Which item on the site (item #?) are the - RELAY AND MOUNT / ADJUSTABLE THERMOSTAT CONTROL UNIT / INLINE SWITCH PORT FEMALE / 14 x 20 ALUMINUM CONDENSER WITH DRIER MOUNTED (is this the Superflow model?)
Looks like parts over the years have gone up about 25% at Nostalgic Air
Anyone have a reasonable source for the AC Pulley part 614718? or ETC8853?
Anyone else done this setup yet? any advice?
I dont have my Defender yet, but its on its way to me! Gotta get ready for the heat.
Old March 22nd, 2017, 12:48 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Hi Piekas,
There are multiple options for each item you ask about...you could go:
Relay and mount
Nostalgic AC - Relay Mount for 30 & 40 Amp Relays
Fan thermostat…you could use either of:
Nostalgic AC - Adjustable Thermostat Control Unit - Relays & Thermostats - Radiator and Condenser Fans
Nostalgic AC - Adjustable Fan Thermostat Relay and Harness - Relays & Thermostats - Radiator and Condenser Fans
Inline switch port:
Nostalgic AC - Binary High Low Safety Switch Female Threads - AC Pressure Switch - Oil, System Flush & Switches
Condenser:
Nostalgic AC - 14 X 20 Superflow Condenser With Drier Mounted
Good luck...
300tdi, tdi
NIB 300Tdi A/C Kit/ System TDI Guy For Sale - Parts 5 June 30th, 2011 08:36 PM
300tdi A/C Compressor Kit Cred For Sale - Parts 4 September 27th, 2010 09:05 AM
300Tdi A/C Compressor Kit Cred For Sale - Parts 6 July 27th, 2010 10:35 AM
300TDi RHD A/C for D-90 natas Wanted 0 May 20th, 2010 01:15 PM
