300td: Does the air cleaner to turbo hose mount somewhere? - Defender Source
Old February 2nd, 2014, 10:39 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Can any of you 300tdi guys tell me if the air cleaner to turbo hose (the one that wraps around behind the engine) attaches somewhere behind the engine? It seems like it should have some kind of support, like around the rear engine lift point, but I don't know for sure or not. Can anyone confirm what happens back there on a 300tdi?
Thanks!
Pete
Old February 2nd, 2014, 10:47 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Not that I've ever seen. The hose is quite rigid.
Geared Restoration Co.
352-572-3236
Old February 2nd, 2014, 10:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I'm pretty sure there is no mid support. The thing is so darn stiff, may just a little pre-load on it's position then clamp 'er down. Also the little thingee's that the air box mounts on, rubber shocks, get some extras cause vibration does kill them.
OK Fine !!! I'll put on my slippers, brave the AZ cold, and go check ....... nope. The only mid point thing is the inlet for the hose to the oil cyclone and the swivel adjustment clamp.
Old February 2nd, 2014, 10:53 PM
Broncoduecer
peter
D90
I've never seen something, but just wanted to be sure. I couldn't find any pics of the hose on an engine that would detail that area, so thanks for the info!
Thanks!
Pete
Old February 3rd, 2014, 10:15 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
no mid support, that's probably why the hose has so many nerves.
- Charles Eames
mount
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
Td5 Over Flow Bottle and Air Cleaner Mount SafariHP The Vendors Loft 0 January 26th, 2009 07:55 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
