300 Tdi timing belt install - Defender Source
Old March 9th, 2006, 10:45 AM
roverboy's Avatar
roverboy
Thomas
Booger
I just got off the phone with my local garage, and they want to charge me $600 to install a timing belt on my 300Tdi. I have already supplied the belt itself, but they need an additional installation kit and some gaskets for the cover.
This seems awfully expensive to me. Anyone have any experience having this done? Is their quote ok or should I shop around? Would any old deisel shop be able to do this? I don't think this is a job I want to try and tackle myself.
Thanks.
"There is absolutely no excuse for the way I'm about to act."
Old March 9th, 2006, 02:03 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Well,
How many hours of labor are you being charged and at what rate? To do the job right would include the tensioners and a crank seal and cover gasket. They are possibly also having to remove the slam panel, grill shell, radiator & intercooler for access. Also, if they are following the SM proceedure, they have probably had to invest in a pump alignment pin and a crank alignment pin to set everything properly....so maybe 4ish hours at $70-80/hr plus parts & shipping & tax...I can see it coming to $600 pretty easily.
I put a belt in the truck I just converted. I did it without a radiator & stuff installed and it wasn't overly difficult but it would have been a real PITA to do with the radiator in place.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 9th, 2006, 04:44 PM
roverboy's Avatar
roverboy
Thomas
Booger
Thanks Rob,
That makes a little more sense to me. The shop I use has done me right in the past, and I think they're good guys, I just wasn't expecting $600+...I went ahead and told them to do it.
In any case, it's cheaper than a new engine.
Tom
300 tdi, tdi
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
300 Tdi Timing Belt roverboy For Sale - Parts 3 March 27th, 2007 09:06 AM
300 Tdi Serpentine belt failure roverboy Defender Technical Discussions 5 May 25th, 2006 02:53 PM
