300 TDi Thermostat - Defender Source
Old July 10th, 2006, 07:02 AM
ronward's Avatar
ronward
Redsrover
None - sadly
300 TDi Thermostat
Winter thermostat in 300TDi makes it run a little on the warm side in this Georgia heat. Need to replace with a "summer" thermostat. Any of you 300 TDi guys know what temperature thermostat I need? Is there a gasket I need to replace as well? New to the 300, so looking for some step by step if possible.
Ron
Anything is possible, with the right tools...
Old July 10th, 2006, 07:58 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Never heard of two different thermostats. Do you have part numbers?
Old July 10th, 2006, 08:46 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Ron? 300 Tdi? whassup?
Old July 10th, 2006, 08:47 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Never heard also of two thermostats. I run my 300 with
factory thermostat in hot weather all year long. May
be you just need a coolant circuit and radiator flush...
- Charles Eames
Old July 10th, 2006, 06:21 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Jack, you up for a coolant flush and genuine thermostat replacement at the tech day this weekend?
Old July 21st, 2006, 05:12 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
They never run hot if the rad is in good condition, the problem is usually getting them up to some sort of temperature. My 110 ran in the Sahara (summer) with the same thermostat as the winter in the UK. The fan clutch kicked in two or three times.
When the core starts to fur up the temp slowly climbs and you have to stop or run slow for the temp to come back bown again. All the little cooling fins rotting and falling off the rad is another issue to look out for.
Mike Hammond
Old July 21st, 2006, 07:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, do you have the stock temp gauge? IF so, change it to a VDO. I thought mine was hot till I put in a good gauge and sender... Also, make sure you run a ground wire from your trans to the frame... I had this problem which caused a faulty temp reading...
Legend in My Own Mind.
Old July 22nd, 2006, 08:38 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Thanks. Pretty sure it's running fine, except the electric cooling fan isn't kicking in. That's my problem right there. Planning to sort that out tomorrow once the spring swap is completed today. Any particular place for the suggested ground wire from transmission to frame?
Old July 22nd, 2006, 09:00 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
when I had the stock gauge in and the ground not set up right, I stressed all the way to MAR. Since it was raining I guess the grounding of the truck was different and I thought I was over heating the entire ride.. Jimmy told me that in the UK he never even had a fan on his Tdi and it never overheated... I would not worry about it..
Old July 23rd, 2006, 09:01 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Well what's got me stressed is this 300 Tdi is fitted with air con and the big cooling rad and electric fan from the air con is in front of the engine coolant rad. Going down the road with the electric cooling fan not working is making it hard to cool the engine coolant rad off. The thermostat I installed has zero effect on any of this, and the engine, water pump, fan, hoses etc are all relatively new (+/- 10k miles). Just hate rolling around at high temps.
-Ron
Old July 23rd, 2006, 04:08 PM
mikeslandrover
Mike Hammond
-Ron
Tdi's don't really like running hot
Mike Hammond
Old July 23rd, 2006, 11:03 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Well we flushed the coolant, looked perfectly fine to me. The cooling system is new as of 2002 when the engine was installed. Runs fine, not overheating, but the guage reads high.
Old July 24th, 2006, 02:10 PM
mikeslandrover
Mike Hammond
Is it actually overheating then?
My temp gauge on the 110 reads lower than the 90's gauge.the 110 reads around 1/3 from base and the 90 reads a little over 1/2, neither change much at all up hill or down.
After a good run both top pipes are too hot to hold and the return pipes to the engine from the bottom of the rad are cool to the touch.
You could try running with the thermostat removed for a while and compare the in/return pipe temperatures.
Its temperatures that steadily climb and climb that are a cause for concern.
It might just be mismatched sensors and gauges, both my trucks are 1984/5 vinage with retro fitted 200 Tdi's and neither gauge reads the same
Mike Hammond
Old July 24th, 2006, 09:29 PM
ronward's Avatar
ronward
Redsrover
None - sadly
It's not actually overheating. I think the gauge is mismatched to the sender.
Old July 25th, 2006, 02:28 PM
mikeslandrover
Mike Hammond
Now that it's established that it's not overheating ....to return to the orrigional question you could go for an 82 thermostst in the summer and an 88 one for the winter, I just opened boxes and compared thermostats at the local Halfords until I found one that was the same size
Once you've established what's normal for your sender & gauge set-up it's a deviation from the norm that you need to watch out for
Mike Hammond
Old March 11th, 2011, 12:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Newbie questions. I am replacing my 300tdi thermostat this weekend. Is there anything not mentioned in the 300tdi workshop manual that I should be aware of when I do this? Are there any seals or gasket that should be replaced when I do this? When draining the coolant, can I reuse it after I am done or do I need to fill it with new coolant? If so what coolant should I use?
Old March 11th, 2011, 12:41 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://forums.lr4x4.com/index.php?showtopic=10681
Read this.
Old March 11th, 2011, 12:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Thomas!
Old March 11th, 2011, 12:55 PM
tjfslaughter
thomas
Burbon
white 90 on the lr4x4.com site has done a shit load of write ups. I usually jump on the google uk page then search "300 tdi thermostat change lr4x4"
here are a few of his write ups:
http://forums.lr4x4.com/index.php?showforum=15
Old March 13th, 2011, 09:10 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I replaced the thermostat and it was a no brainer with the exception of the coolant drain. I can't access my lower radiator bottom hose (to drain) because there is all sorts of of things in the way (skid place, etc). Is there another way to drain coolant without making a mess? I used the return supply line to the expansion tank... unfortunately it was messy.
One other question. There are supposed to be two electrical connectors to the water temperature switch connected to the bottom of the elbow housing. I do not have these and they are nowhere to be found. Just two empty sockets. What am I missing? Is this where the coolant temp gauge is supposed to connect?
300 tdi, tdi, thermostat
300 Tdi A/C question... roverboy Defender Technical Discussions 3 September 17th, 2005 02:15 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
