300 tdi conversion - Defender Source
Old March 19th, 2006, 10:56 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
300 tdi conversion
I really tried to search this and other sites befor I asked this question, so I am sorry if it was right in frot of my face and I didnt see it. What does it take to convert a NAS 1995 v-8 d-90 to a 300 tdi? Details, like can I use the same transfer case, fuel lines, gas tank, anything need to be cut other than moter mounts, do you need to wire the engine, etc. Thanks.
Byron
by the way I am looking for info on a minimal conversion NOT ground up. Want to keep the same frame and everything else that i poss. can.
Old March 20th, 2006, 12:43 AM
Shane@EVS
Roverhybrids
300tdi engine with accessaries
300tdi transmission etc.
exhaust.
crossmember
radiator
innercooler
few gauges
you could reuse your fuel lines but you need to remove the in tank fuel pump and rearrange the internals.
different fuel filter(s) these would require fuel line mods.
different fuel filler neck and gas cap.
You can keep you transfercase.
Drivelines are a little different
engine mounts have to be cut off and new ones welded in place.
I think that covers most of it but I am sure I missed some details.
Labor from a shop is usually around $3000.
part range from $7000- $15,000
Old March 20th, 2006, 01:03 AM
Thats pretty much it!
Old March 20th, 2006, 08:15 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
why the transmission? different gears, or length of shaft I would presume. are the mounts of the transmission different? Drive shafts the same? Cross member for the transmission? What guages? What about electrics? How do you wire in the new 300tdi?
Old March 20th, 2006, 08:36 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Wink
That's what i like about 300Tdi (without ECU) : (almost) NO WIRES
- Charles Eames
Old March 20th, 2006, 10:06 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Call RoversNorth and ask for Les. Ask him to send you the part list from the old kit they used to sell. 300TDI conversion. You'll know exactly what you'll need.
EwS
Old March 20th, 2006, 11:35 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
About to try this myself...
Byron,
I'm about to start this myself...I haven't got my kit yet but expect to do this during the month of April. Any questions just shoot me a message...
George
Chicago
Old March 20th, 2006, 11:42 AM
mattarm's Avatar
mattarm
Matt
1993 D110
If you get this parts list, can you please post for reference?
Old March 20th, 2006, 11:48 AM
http://www.defendersource.com/forum/...ead.php?t=4068
Old March 20th, 2006, 12:41 PM
Gkase's Avatar
Gkase
George Kase
here's the old RoversNorth 300Tdi brochure
Check out this link for a pdf of the old RoversNorth kit offering of a couple of years back...
http://www.landrover.ee/est/files/ma...ine/300tdi.pdf
George
300 tdi, conversion, tdi
300 tdi lrnasd90 Wanted 2 July 29th, 2005 06:55 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
