3 link safari guard - Defender Source
Old November 21st, 2006, 10:37 AM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
3 link safari guard
was curios, i've asked a couple forums and recieved a couple responses, I have a 90 with ARB front, Rear, GBR front axel, RT rear axel, OME 2.5 lift, 35's, and 4.10 gears on my 90 currently. Has anyone had or installed the 3link safari guard 3 link addition to the suspension. I wanted to know what springs, and shocks you went with and how was the results on the street. I had something simliar done to my old DII which i no longer own which was terrifying to drive on the freeway in LA, which is why i sold it .
1995 D90sw #51 (Converted to ST)
1997 D90ST
2006 LR3 HSE (untouched... for now)
Old November 21st, 2006, 01:06 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Anthony-
I have a SG Stage 3/FOX shocks installed w/ the 3-link on my 97 SW. I went with Rovertym springs instead of the OME & 1/2" lift blocks that SG supplied. I am running 315 (35") BFG MTs on stock alloys with wheel spacers. I also have a Currie Anti-Sway bar installed on the rear to help out. The ride is pretty good, but it still sways a bit if you have to make a quick turn. I have debated going wiht aftermarket rims to widen the stance a bit, but really like the way the stock alloys look. IMHO, the 3-Link works very well off-road, but is marginal on road. I have really adjusted my driving style to compensate for it.
Old November 24th, 2006, 12:24 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I like the 3 link on the 110 w/t NO sways!! I think it handles better than stock!!!
Old November 27th, 2006, 12:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have almost the same setup.. with the 3-link
Legend in My Own Mind.
Old April 13th, 2007, 07:10 AM
UkChris's Avatar
UkChris
Chris Fordham
1999 D90 TD5 3link
Hi guys, the three link we use i believe is simular to the SG version, ours handles better than stock, but we spent the best part of a day setting it up as everything is adjustable, e use +2 OME springs with inch spacer blocks underneath, adjustable panard rod to move the axle back in line...
I was taliking to one of our US customers today who was convinced that in the US 3link vehicle have a restricted speed limit applied to them as they are considered dangerous on the road ? Is this true or not ?
Uk Td5 D90 3link... 250Bhp and lots of black smoke !
Online ordering at
Old April 13th, 2007, 09:58 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't know if it is technically true or not, but what cop is going to a)know it is illegal b)know what to look for & c)climb under your truck to check?
Plus at worst (in IL anyway) it would probably just be a compliance ticket that all you would have to do to get it dismissed is show them a receipt for removal and they drop the fine.
Either way, I wouldn't loose any sleep over it.
Old April 13th, 2007, 08:26 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I don`t think it`s a legality issue so much as a safety issue. Face it, nobody is going to know until something happens.
Old April 14th, 2007, 09:29 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
My truck runs great with the setup I have.. RYM springs and no sway bars at all... 75mph all day long.. I am running 15x8 with 4" backspace rims though. Wider stance
Old April 18th, 2007, 09:13 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
+ one
I run a 3 link daily. Cross country highway, on the trail and I love it. No issues, no problems.
Most states do not regulate suspension design changes, just ride heights and such.
Email:
Old April 19th, 2007, 03:44 PM
Quick Hi-Jack. A buddy of mine has a 3 link he may sell me... Do I have to relocate my shocks from the standard factory location? Is it something I can do at a later date? Also, it was off a disco 1. The cross member lines up to mine, and it looks the same and looks like it would work. Any thoughts?
In case you need it: I have about a 4" lift, OME with 2" spacers, Rancho Ajustable Air shocks, (Rockware set up) and both GBR HD DC Driver shafts, ARB's and 4.11's, GBR HD axels 's in the Rear and CV Unlimited up front.
Old April 20th, 2007, 02:40 AM
Shane@EVS
Roverhybrids
The defender frame is about 1" talller making the crossmember not an ideal fit. I could be modified to fit, but it is not a direct fit.
Old April 25th, 2007, 12:29 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
will that 3-link crossmember for the D-1 fit on my 92' classic
Old April 25th, 2007, 04:35 PM
Maybe... probably... You could easily make one. It is pretty simple and straight forward. I am planning on augmenting it slightly to make it work.
Are you going to Uwharrie next week?
Old June 11th, 2007, 04:01 PM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
I'm finally giving in, and going to install the 3link. I am trying to figure out the right shock lenth though. FYI i have no problem cutting the front fenders, although they have saved me oh so much damage to the side of my truck against big rocks. Currently i am running 35x12 procomps with 4 1/4 backspacing on 15in wheels on 3in RTE springs with 7100 bilstiens. I am planing on moving the shock outside the shock mount and try and go with a longer shock. Questions i have are how long should i really go without restricting the front. Also I currently, have rte springs, on there shockmounts. There not much selection on mounts for moving the shock outside the spring mount, other than SG or fabing something up and wondering if it's going to hold up on a one off. If someone knows an UHH cheaper way to acomplish this please do tell. Or am i just wrong on the moving the shocks outside the existing mount buying any extended travel?
1997 D90ST
Old June 11th, 2007, 07:54 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Keith has some cool mounts I have his on the 110 & they work well. They keep the shock on the inside but youll still have to cut the fender well.
I have 2.5 =3 inch lift with 7100 12'' short bodys no disslo [1/4] but my springs are SR progressive.
I would call Keith & he will point you in the right direction.....
Peter
Old June 12th, 2007, 01:27 PM
Dredd
Harlan Boone
Anyone but Safari Gard
Are there any vendors in the US selling a 3-link setup for the D90 OTHER THAN safari gard?
HB
Safari Guard grill screws needed Caribsurf Defender Technical Discussions 7 February 26th, 2007 03:57 PM
safari guard bumper ends skibigwest Wanted 0 March 13th, 2006 04:41 PM
Problems with the safari gard 3 link? kevinumali Misc. Chit-Chat 7 March 2nd, 2006 10:15 AM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
Greg and Brandi Jevne chrisvonc Defender Owners 0 February 22nd, 2004 09:38 PM
» Defender Registry
MIke's D90
usla1
TIT
SaltyDog
Add your Defender
