3 Link Angles To Reduce Vibs ? - Defender Source
Old December 31st, 2005, 12:28 AM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I'm having vibration issues after the 3 link was installed starting at about 1900 rpm, but as I let off the gas the vibration stops. What degrees should I have set to reduce the vibration. What degree are you running at the pinion angle and the driveshaft. I replaced all the bushings, balljoints ,panhard rod bushings, wheel alignment and also have front DC and rear DC driveshafts (GBR) installed.
Old December 31st, 2005, 02:36 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
jorge, call me
Legend in My Own Mind.
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
Drive Shaft Angles TDI Guy Defender Technical Discussions 27 March 17th, 2004 06:10 PM
