3.9L V8 Water Pump Install on NAS D90 - Defender Source
Old August 21st, 2016, 10:08 PM
Grover's Avatar
Grover
Question 3.9L V8 Water Pump Install on NAS D90
This is in reference to a thread I started in the misc section "Well after 21 years..." about my water pump. Maybe these should be merged...
My question is, have those of you how replaced your water pump, how did you clean the female threads in the block behind the timing cover, or did you even worry about it? Will remaining coolant in the threads affect the performance of the thread sealant? I ended getting Permatex High Temp Thread Sealent for the job.
After I puled the pump, I jacked the back of the truck up about 4" to drain out more coolant.
Anyway, looking forward to your comments...
Cheers...
Old August 22nd, 2016, 08:57 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I didnt worry about it. And haven't had any problems with mine leaking. Make sure you have all the bolts in the right order/location. They vary in length as I remember. I made a cardboard cut out that mimicked the gasket and as I pulled the bolts I stuck them in the cardboard in their correct location. Made it easy when putting them back in. Also after I replaced the pump and coolant I had a ton of air in the system that I had to burp.
Old August 22nd, 2016, 09:13 AM
Grover's Avatar
Grover
Question
Good to know, thanks. What thread sealer did you end up using?
Old August 22nd, 2016, 09:44 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Used cardboard like Bill ... plain old Locktite brand thread sealant. White stuff in a little tube. works like magic
Old August 22nd, 2016, 10:02 AM
I've never cleaned the threads when doing a water pump.
x2 for marking where all of the bolts go.
90, d90, nas, v8, water, water pump
97 NAS Water Pump, Viscus Clutch, Thermostat 1of40 For Sale - Parts 0 September 25th, 2015 05:56 PM
Smaller NAS 110 water pump pulley mattm Defender Technical Discussions 2 July 12th, 2014 02:51 AM
New aftermarket water pump -'97 D90 smob For Sale - Parts 0 January 25th, 2014 04:10 PM
Water pump for 97 NAS D90 imeek For Sale - Parts 6 November 23rd, 2012 07:42 PM
water pump? install? proline vs LR? tebby Defender Technical Discussions 5 May 17th, 2010 12:27 PM
