3.9L V8 Timing - Defender Source
Old August 31st, 2015, 10:59 AM
Grover's Avatar
Grover
Question 3.9L V8 Timing
The D90 is pushing 100k on the original engine. All I've done to it aside from maintenance is a HG and valve job. Any y'all with high miles on your engines advance the timing due to timing chain stretch?
1995 NAS D90 3.9L V8
Cheers...
Old August 31st, 2015, 11:20 AM
I 'd be suprised if a timing chain could stretch enough to make timing difference that would be greater than the variance of setting the timing.
I set mine with a snap-on oscilloscope to the book values and get around 15mpg on a run and occasionally nearly 18mpg. My truck exhaust does smell a bit rich but I suspect this is cats / O2 sensors rather than anything to do with timing.
Do you have any symptoms other than having read the internet? ;-)
Old August 31st, 2015, 11:31 AM
These engines can go well into 300 grand without any issues at all. Change the oil, keep up with tune ups and don't mash the gas a lot...you'll be good.
Old August 31st, 2015, 11:35 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
18mpg? Tell us your secret.
Old August 31st, 2015, 11:58 AM
Following Jimmy to Wintergreen from NYC to VA and back again I got almost 18mpg. I wasn't that close to be slip streaming but i was very surprised. The Oscilloscope was really cheap on craigslist ($150) and it does a great job of helping set the timing and seeing any other issues in the ignition system. You can even measure the spark gap to make sure it's right and it helped me diagnose a faulty lead that was causing me some major running issues in about 10mins of turning it on ... and I'd never used one before.
Snap-On Counselor MT1665 Digital Oscilloscope is what I have and it's perfect for the vintage of these trucks.
Old August 31st, 2015, 01:48 PM
mine was set way advanced at 15 degrees, and popping the check engine light after 15 min of running, i reset it back to factory spec (5 degrees) using my old the trusty craftsman timing light, and it runs great now.. fuel mileage "seems" to be up as well with that as the only change to fix the CEL. I did also install a new maxflow y-pipe but the same CEL issues persisted after that install, that was done to fix a rattling Right side Cat converter.
just keep it at factory Spec, make sure your putting enough oil in it after a change and keep it topped up, and do the regular maintenance, and you should be fine for many more miles to come.
Mine just turned 135k
95' D90 - daily driver..
Old August 31st, 2015, 04:35 PM
The timing chains do stretch, but I don't think this correlates to ignition timing. IMO, change the timing chain at that age. It really cuts into power and use a proper chain instead of the piece of crap that Rover supplies.
Old August 31st, 2015, 07:07 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Yes, the timing sets do wear and retard the cam timing, making the engine sluggish. I am also not a fan of the nylon timing gear, so I installed a Cloyes timing set. I do think the worn timing chain affects the ignition timing as the distro drives off the cam, but not sure if the chain tension reverses as the engine runs so if timed while running, you probably won't notice. If you have the timing cover off, your should replace the oil pump too - FWIW.
Name:	Timing Chain.jpg
Angus
Old November 11th, 2016, 10:33 AM
Grover's Avatar
Grover
Question
Does the Cloyes double roller timing chain require modification to the front cover of a v-belt distributor 3.9L Rover V8?
Which one are y'alls using?
Here is a single:
https://m.summitracing.com/parts/clo...FYE2aQodUFML3w
Here is a double:
http://www.thewedgeshopstore.com/clo...-timing-chain/
Old November 11th, 2016, 10:57 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
The double fits fine on a 3.5.
Old November 11th, 2016, 11:04 AM
the cloyes will fit anywhere the single was used. I use the double.
Old November 11th, 2016, 11:16 AM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Bolted right in my 3.9. No mods at all.
Angus
Old November 11th, 2016, 11:46 AM
doktorno
Chris deZ.
1995 Defender SW
Was nylon used for noise reasons? Just curious.
Old November 11th, 2016, 12:00 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
That is the only benefit of a nylon gear, although I am not sure I can hear any increased timing chain noise over the cacophony of other mechanical noise.
Angus
Old November 11th, 2016, 12:51 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
My first 3.5 I replaced had a lot of missing teeth on the nylon gear...
Old November 11th, 2016, 01:45 PM
Grover's Avatar
Grover
Yikes...missing teeth?
What Is the Cloyes part number? I'm also seeing Cloyes 9-1132 fits the Rover 3.5L/Buick 215...
Old November 11th, 2016, 02:00 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Here is the set I used. Not Coyles, but CompCam.
Name:	3.9 timing set.jpg
Angus
Old November 11th, 2016, 02:48 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I got most of my top end parts from Woody at the Wedgeshop. He's very helpful if you have any questions.
v8
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Why didn't anybody warn me timing chains are so annoying? Hans Misc. Chit-Chat 4 January 16th, 2005 11:40 PM
