3.9L Oil Pressure at Operating Temp and Idle - Defender Source
Old September 24th, 2016, 01:23 PM
Grover's Avatar
Grover
Question 3.9L Oil Pressure at Operating Temp and Idle
For a Rover 3.9L with a distributor driven oil pump, what should be the oil pressure at operating temp and idle?
The workshop manual states at 2400rpm and operating temp the oil pressure should be 1.76kg/cm^2 (~35psi)
States nothing about idle.
Thanks!
Old September 24th, 2016, 02:27 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Originally Posted by Grover View Post
For a Rover 3.9L with a distributor driven oil pump, what should be the oil pressure at operating temp and idle? The workshop manual states at 2400rpm and operating temp the oil pressure should be 1.76kg/cm^2 (~35psi) States nothing about idle. Thanks!
I don't like to see oil pressure go below 20psi.
Black Rhino Lives Matter
Old September 25th, 2016, 08:32 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Idiot light comes on around 7psi... but that's sounds scary low. I recall around 15 being normal.
idle
3.9 operating temps Seanh Defender Technical Discussions 1 June 21st, 2016 12:47 PM
200tdi operating temp Naplm00 Defender Technical Discussions 16 December 8th, 2010 03:58 PM
Idle Oil Pressure? bomilcar Defender Technical Discussions 5 March 25th, 2007 08:03 AM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 12:10 AM
D90s Operating in Today's Pakistani Offensive wicks Misc. Chit-Chat 4 March 18th, 2004 07:14 PM
