3.9L Lower engine harness - Defender Source
Old October 13th, 2013, 01:19 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Is there a separate part number for the engine side of a 3.9L wire harness. The part that is essentially the starter, alternator, engine temp, etc side.
I don't really want to cut the chassis side connectors. So I was hoping that the engine side of the harness is available-ish. I'd love to use the existing connectors and not cut anything for my Tdi doings.
Anyone have any ideas?
Old October 13th, 2013, 09:46 AM
A buddy of mine hooked his battery up backwards and melted that harness. I ended up using a Range Rover Classic harness. I did have to do some modifications to it, but it looked pretty good when I was done with it.
What are you trying to accomplish? If you're just trying to get rid of the unused connectors you can open up the heat shielding and just remove the unused wires and connectors. There isn't much to that part of the harness and it unbolts separately from the fuel injection harness.
Old October 13th, 2013, 12:12 PM
Broncoduecer
peter
D90
Hey Jimmy,
I was trying to keep the stuff for my 3.9L complete so when I go to sell it, it can be considered complete, you know to add some attractiveness to it. But I guess the only things I really wanted to do was re use the firewall connections for the starter solenoid connector and a couple wires off the other connector for the oil pressure light and tach. I can make new stuff, but it would be cool to use the existing connectors as much as possible.
Pete
Old October 14th, 2013, 05:32 PM
Broncoduecer
peter
D90
On a side note: anyone here have a 1994 wiring diagram?
I have the rave cd, but like most have noted, it's for a 97. So a little different.
Searching through the old forums didn't give much, a few dead links that looked promising though.
Pete
Old October 15th, 2013, 10:43 PM
Look at a Range Rover classic diagram, it should be close.
engine
1994 3.9L engine - - FREE tonydownunda For Sale - Parts 14 February 20th, 2013 11:25 PM
94 NAS Chassis Harness chris snell Smaller Projects 4 February 3rd, 2013 01:16 AM
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
