3.9L idler pulley bearing - Defender Source
Old November 9th, 2015, 01:43 PM
Grover's Avatar
Grover
Question 3.9L idler pulley bearing
Anybody have a part number? I just want to replace the bearing not the entire assembly.
Cheers...
Old November 9th, 2015, 02:44 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I just use a 6203. It is a common bearing used in a lot of applications, should be available from any auto parts store. They are commonly used as pilot bearings. The snap rings are hell to get out. I heat them with a torch to kill the spring tension and replace them with ones I get from NAPA that have the holes for the snap ring pliers.
Funny story....my parts washer started making funny noises and I had a project that required it with a hard deadline. I took the pump motor apart, found a 6203 bearing had failed, replaced it with a bearing I pulled out of a used Discovery tensioner pulley (because it was 10 PM and I couldn't get a new one and couldn't wait). That was about 5 years ago and it's still working great.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 12th, 2015, 12:31 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
Just in case you're still looking for the original part number, it's 614154.
idle, pulley
idler pulley bearing 300TDI lrna04 Defender Technical Discussions 12 November 18th, 2013 04:19 PM
tensioner pulley bearing floatflyer Defender Technical Discussions 7 February 1st, 2010 08:54 AM
'97 Serp Idler Monkeyboy Defender Technical Discussions 4 May 15th, 2009 01:39 PM
Part Number for AC Idler Pully mgrgpg Defender Technical Discussions 2 August 4th, 2005 10:07 AM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
