3.9 with Supercharger set up - Defender Source
Old June 22nd, 2009, 09:03 PM
budz
sal gorriceta
various rovers
Anyone here that has 3.9 V8 with Supercharger set up? I need some pictures where the lines are hook up. Also 97 AC system installation guide. Thanks
Old June 22nd, 2009, 10:33 PM
JimC has the AC install stuff. You finally getting the blower on the rig?
Old June 22nd, 2009, 11:11 PM
budz
sal gorriceta
various rovers
Yup, supercharger installed today but still needs some guidance where lines are supposed to be. Thanks for Jorge for letting me take some pictures of his 97 with SC set up but 4.0 and 3.9 are totally different. Will try to pm JimC.
Sal
Old June 22nd, 2009, 11:47 PM
What lines? Coolant?
Old June 23rd, 2009, 04:32 AM
budz
sal gorriceta
various rovers
Vacuum lines and some?
Old June 27th, 2009, 10:02 AM
budz
sal gorriceta
various rovers
Car starts and running but I need guidance where the rising rate regulator lines are hook up? Also t piece is not connected, Do I need to connect it? Thanks..
ID:	20280   Click image for larger version
ID:	20282   Click image for larger version
ID:	20284   Click image for larger version
Old June 27th, 2009, 10:30 AM
turbodave
Dave C
1983 110
I don't recognise the regulator, but the centre at the bottom is usually the return to the tank, the one next to it must therefore be from the pump. The small port at the top needs to be connected to the intake, before the throttle so it doesn't see vacuum - or maybe after if you want it to see vacuum. Like i said - it depends on the type....
What controller are you using on all this?
I hope you have a dual-wideband setup - if not you run the risk of doing a lot of damage very quickly.
Old June 27th, 2009, 01:59 PM
budz
sal gorriceta
various rovers
Dave, Pm sent.
Sal
Old June 29th, 2009, 11:54 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Pics?
I got my 94 here at the office today, what pics of the SC do you need?
Old June 29th, 2009, 06:46 PM
budz
sal gorriceta
various rovers
Josh,
Pls. send pictures to budznewyork@yahoo.com. All angles if you can especially rising rate fuel regulator lines from stock regulator and all pipings if you can. Also if you can leave your contact number.
Sal
Old June 29th, 2009, 10:42 PM
budz
sal gorriceta
various rovers
Best place to buy air/fuel ratio meter and fuel pressure gauge? Brand?
Old June 29th, 2009, 10:54 PM
imeek
Isaac
Red 94 D-90 (SOLD)
I would suggest you contact www.bellengineering.net. The regulator you have is probably from them, and they can rebuild it and make sure it's in working order. You can also find the other parts you are looking for there.
GL
FS: 3.9 injector set Hans For Sale - Parts 1 September 6th, 2009 01:55 PM
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
Value of 3.9 engine Doug For Sale - Parts 4 April 20th, 2004 03:36 PM
