3.9 to 4.6 upgrade options - Page 2 - Defender Source
Join the Defender Source Community Today
Old June 27th, 2016, 04:23 PM
fishEH's Avatar
fishEH
Brett Fritzler
1998 Discovery
Originally Posted by 1of40 View Post
Yeah, you'll probably notice a peppiness with the 412's. Be careful re exhaust. The higher rpms will give you a drone that sucks at highway speeds over long periods of time. Double check tire size again. My 255's are true 33's not 35's.
10-4. I've already had this setup on my 98. Headers, MagnaFlow hi flow cats, Borla cat back, with the 4.12's on 315/75 KM2's. It sounded pretty badass when I got on it. It had some drone at highway speed. Not terrible, but I'll be looking to tone it down a bit this go around.
Old June 28th, 2016, 01:55 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by o2batsea View Post
You should buy Tony's built 14CUX 4.6.
I was going to say the same thing...
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 28th, 2016, 02:41 PM
blaughva's Avatar
blaughva
Bradford Laughlin
95 D90 SW #141
When I did my 4.6 I spoke to Mark Adams (Tornado Systems) and he was very adamant about not using 4.0 pistons. I took his word as it carries a lot of weight when it comes to 4.6 engines.
Originally Posted by fishEH View Post
That's where I'm headed I think. I do all my own work.
Got a link or full user name?
Old June 28th, 2016, 02:58 PM
fishEH's Avatar
fishEH
Brett Fritzler
1998 Discovery
Did he say why? Not that I don't believe him/you...I just like to know the why so I understand better.
Old June 28th, 2016, 03:07 PM
blaughva's Avatar
blaughva
Bradford Laughlin
95 D90 SW #141
Here is what he wrote:
"The only concern I have with your conversion is the use of 4.0 pistons. You do need to be careful using the 4.0 Litre pistons in a 4.6 engine, as it can produce an extremely high compression. Typically this will be 10.9:1 assuming that the heads have not been skimmed at any time. This will require a very high Octane fuel to prevent pinking/detonation, which I believe is not easy to get in the USA.
Even if you use the earlier 3.9 heads the compression will still be around 10.0:1, and you would then have the difficulty of mounting the ancillaries to the heads. Really it is a combination I wouldnt advise."
Old June 28th, 2016, 03:16 PM
Ray_G's Avatar
Ray_G
Ray Gerber
96 D1 (Coyote), 06 D3
Sharing a lightly edited dialogue with a friend and long term Rover owner just because his words convey context to the 4.0 piston discussion:
You can do the 4.0 pistons for just a bit more cost and it does make a difference. If you port and polish the heads to truly get the benefits you want to put a performance cam in it too. All of those should be reliable. I run a 4.6 with 4.0 pistons stock cam and heads. I have almost 50,000 miles on that set up I put it in the winter before Oakridge. Truly no worries but it does push oil due to the compression and it is leaking oil but don’t they all?
I did a stock 4.6 in ___ truck so she would not have the Premium gas worries
If you do the 4.6 with 4.0 pistons you MUST run good premium gas.
Opening the heads and adding the cam will add - if you did the 4.0 pistons heads and cam I can see you getting close to almost 245hp NO proof or Dyno to prove that estimate but a stock 4.6 should net you 220hp. I guess if you don’t mind the premium gas think of it this way. You will add around $1000 to the build and it will feel like going from a 195 hp 4.0 to a 220 hp 4.6 only you will be going from a 220 hp 4.6 to a 245 hp performance 4.6. It should be reliable and dependable with no worries. The GEMs fuel mixture can handle it without a CHIP but if you added the Mark Adams Chip to work on the timing and mixture (costly $1700) you might even gain another 10 – 15 hp. How much is enough? and how far do you want to go?
Keep in mind this was for a GEMs engine and I do wonder if the fuel management system there may be a little more forgiving but that's supposition on my part. The emphasis I added was to illustrate a real world long term (I consider 50k in a Rover long term) application.
Put another way if/when I start building a replacement for Coyote I'll likely find a 4.0 GEMS block (i.e. not the later year 4.6 blocks), put a 4.6 crank/rods in it with 4.0 pistons, port/polish myself and a mild cam. That's daydreaming of course. First I have to have little things like my household goods show up and such....
Old June 28th, 2016, 03:27 PM
blaughva's Avatar
blaughva
Bradford Laughlin
95 D90 SW #141
Good input Ray. Although I run 4.6 pistons I do have a stage 2 crower cam as well as Mark's chip (It's around $650... but on sale now thanks to Brexit), a setup which also requires premium gas. There is definitely a noticeable difference from my 3.9 which makes paying more for gas acceptable.
Old June 28th, 2016, 03:36 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
So are the 4.6 benefits primarily in 0-60 or 70-90?
Old June 28th, 2016, 03:43 PM
blaughva's Avatar
blaughva
Bradford Laughlin
95 D90 SW #141
I've noticed a significant increase in pick up. I almost always start in second, even on incline. I can also (not that it is a good idea) cruise at 80.
Old June 28th, 2016, 04:05 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
In my D2, I found the 4.6 benefit mainly from 24-32mph... or not at all
Rent my
Old June 28th, 2016, 04:11 PM
fishEH's Avatar
fishEH
Brett Fritzler
1998 Discovery
As in MPH? I would hope 0-60. My highway cruising speed is 65-68mph and I get around 16-17mpg. Maybe more if I factored in the larger tire size/slower odometer.
I have no desire to push 70+mph in a D1.
Old June 28th, 2016, 04:14 PM
Ray_G's Avatar
Ray_G
Ray Gerber
In my D2, I found the 4.6 benefit mainly from 24-32mph... or not at all .
I wonder if that's the dif in curb weight, that big ass on a Dii does add a bit
Old June 28th, 2016, 04:16 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
"Does this D2 make my butt look big?"
yeah, the D2 is a bloated pig.
A 4.6 in a RRC or a D1 is a slightly worthwhile endeavor...
Rent my
Old October 1st, 2016, 01:18 PM
Sned's Avatar
Sned
1994 NAS D90
94 ecu
If you project is complete any chance you want to part with an ECU? 94 NAS
------ Follow up post added October 1st, 2016 12:20 PM ------
Any chance you want to part with a spare 3.9 ECU for a 94 NAS?
Old October 1st, 2016, 02:19 PM
cdb
Clark Bowen
If he doesn't want to I have one from my 1994 D90 from when it was converted to a diesel.
2011 RR HSE -
2001 GMC 2500 4wd
Old October 3rd, 2016, 03:22 PM
Sned's Avatar
Sned
1994 NAS D90
Sure I'll take it. Look for PM.
Old December 29th, 2016, 04:07 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB & '83 110 HCPU
For what it's worth as far as "closure" on some topics here - I have Tony's 4.6 project motor in my garage now, finally on an engine stand. Shortblock is on the stand, I should say. Build up will commence any day now. However, will not be bale to comment on performanc ein a D1/D2 as it's going in a HCPU that I'm trying to keep as light as I can.
Rovers, Guns, and Airplanes... Willing to share my Ramen Noodle Recipes!
'95 RRC County
'95 RRC
'01 P38
Old December 31st, 2016, 03:03 PM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
I had a 3.9 for years in my D90 and the replaced with the 4.6. Crower high torque cam, Pendy's refuelling chip, slightly overbored using RealSteel pistons. I had 60K on the 3.9 so not used up by any stretch and I did notice a difference between the two motors. I live in CO and the hills are everywhere and I went from sluggish on the hills of I70 by the tunnels to being able to keep up alright. Stock gearing. It is a good upgrade.
Now that I am towing an offroad trailer, however, I am looking for something a little more grunt/low end torque... Still deciding on what. Maybe a TD5, maybe a 2.8 Cummins, maybe an LS.... If it wasn't for the towing, I'd be perfectly satisfied with my 4.6
200tdi Alternator Upgrade Options? RovingRyan Defender Technical Discussions 30 May 12th, 2016 08:08 PM
clutch upgrade wherzig Defender Technical Discussions 4 April 22nd, 2005 05:09 PM
ECU Firmware Upgrade? Doug Defender Technical Discussions 0 March 18th, 2004 07:39 PM
spring upgrade for ARB stanman For Sale - Parts 0 February 19th, 2004 11:38 AM
What's your best/favorite mod/upgrade (poll)? OCD90 Misc. Chit-Chat 24 February 18th, 2004 05:02 PM
