3.9 Timing Check - Defender Source
Old October 25th, 2012, 03:57 PM
trumphair
Martin
97-D90
3.9 Timing Check
Where do I aim the timing light on a 3.9? Anybody want to give me a quick 123 on it as I've never done it? It's a RRC but assume it's the same as the defender? Thanks.
Old October 25th, 2012, 08:20 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
its not easy .... i recommend marking the balancer to give you a 1/2 a chance on seeing it .. you have to aim the light a bunch of different ways while looking between the inside of the p/s bracket and the water pump
No Mall crawler here
Old October 25th, 2012, 08:57 PM
Ha! trick question! You can't aim the timing light AND see the mark at the same time.
Old October 25th, 2012, 09:21 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Ive never had a problem, either on v belt or serp belt trucks... but I always take some sandpaper and clean up the marks on the balancer first, then mark the spot that I want to line up to with paint.
If you are having a lot of trouble, warm the truck up, then pull the fan/shroud off and you don't have to be nervous about losing a finger or two in the process.
Old October 25th, 2012, 10:07 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
It's also not possible to do it in anyplace but a dark room while wearing night vision googles
Old October 25th, 2012, 11:21 PM
trumphair
Martin
97-D90
Thanks for the replies. As with most things, it sounds more difficult than I thought it would be!
Old October 26th, 2012, 03:00 PM
trumphair
Martin
97-D90
Ok so I think I got it read correctly.
9.6 BTDC. Now, how do I actually adjust it say if I wanted to get it to 5-6? Manual says "loosen distributor clamp bolt" but it would help to know where that is on the distributor. Do I have to pull the cap off first? And then once the bolt is loose, what do I actually rotate and in which direction?
Thanks!
Old October 26th, 2012, 04:43 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
the bolt is to the right of the distributer shaped like a Y that clamps down on the base.... think its a 15mm
Old October 26th, 2012, 06:29 PM
Grover's Avatar
Grover
Very little room, I cut a spanner in half in order to get to it.
Loosen just enough to allow rotation of the dizzy, also bring the motor to temp and remove and plug the vacuum line going to the dizzy, then set timing.
Defender 3.9 timing tmore Defender Technical Discussions 1 April 6th, 2006 07:22 PM
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
