3.9 oil pressure switch - Defender Source
Old May 1st, 2010, 06:01 AM
discoinjapan's Avatar
discoinjapan
Michael Bruzga
93 D1/ 94 D90 ST/96 D1
Found out that it is leaking bye. I have a good used one and I also have a few new copper gaskets. If I pull the switch how much oil will I loose?? I'm sitting at home just messin around with the truck and only have about a quart of oil left in the shed.
My question is when I pull the switch will a quart of oil be enough to top me back off?
I cant foresee too much oil draining out since it is above the pan..
TIA,
Old May 1st, 2010, 10:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You'll be fine.
Old May 1st, 2010, 06:57 PM
discoinjapan
Michael Bruzga
I already found out. Thanks. Couldn't wait, did it last night.
switch
Oil Pressure Switch Adapter Firemanshort Defender Technical Discussions 1 June 7th, 2009 01:31 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
