3.9 Cuts out for short period of time - Defender Source
Old September 14th, 2014, 06:27 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Just recently my 3.9 will randomly stall/cut out almost completely for about 2 seconds and then come back to life.
Mostly when I am in 3rd gear running about 2500rpms.........it's like you pull your foot off the accelerator quickly for a second and then bam, it comes back to life. (what it feels like, not what actually happens).
Really crappy description, but hopefully you get the idea.
Any idea what it might be?
Old September 14th, 2014, 06:35 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
Sounds like the magnetic pic-up air gap is not right. Check spec.
Old September 14th, 2014, 06:46 PM
thinking horses not zebras ,., have you checked the air hoses ... the big plenum one can cause this if its loose.
Old September 14th, 2014, 07:04 PM
Third guess ignition switch intermittent failure
Old September 14th, 2014, 07:24 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Ooo a wild guess thread, I'll play
Broken motor mount, pulling the coil wire tight, engine stalls and sits down, coil wire connections restored
Old September 14th, 2014, 08:51 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Intake Hose?
Nope, tight.
No broken mounts or tight wires.
Old September 14th, 2014, 09:12 PM
Is the issue repeatable?
If it is then maybe you have a bad spot on your throttle position sensor.
Rover gauge would diagnose that nicely by a multimeter measuring the resistance would be a second option.
Old September 14th, 2014, 09:20 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Random, but repeatable.
Just drove a 600 mile trip with no hiccups, then all of a sudden it started. Not every time I get into 3rd, but randomly repeatable.
Old September 14th, 2014, 09:58 PM
Any codes on the ECU?
Old September 14th, 2014, 10:06 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Not right now.
It had 48 on it which I think is Idle related..........the little sensor has been clogged up before. erratic idle, etc.....
Old September 14th, 2014, 10:12 PM
cascade90's Avatar
cascade90
Mason Worley
On the air gap thought...it's a lot like point gap of old. There are worn out bearings involved here. That's normal for sure. If I remember right the spec on these is like .009-.014. That's pretty tight. Wide gap equals short dwell time an narrow is opposite. The swing or spec comes from known wobble. It makes a world of difference when you can hit the middle around .011. Easy to set but don't just check in one spot. Rotate the crank one turn or dist. A half turn. I've seen this random issue before. Good luck
Old September 14th, 2014, 10:45 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Bad ignition switch? (or is that just a Series problem?)
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 15th, 2014, 01:47 AM
Hey no stealing my guess, (post 4), I wanna win the prize!!!!!
Old September 15th, 2014, 10:54 AM
It's just a GM problem ...
Old September 15th, 2014, 12:03 PM
Grover's Avatar
Grover
Ignition module
Old September 15th, 2014, 12:25 PM
cascade90's Avatar
cascade90
Mason Worley
Hey these are all pretty good! All over the board. We'll figure out what it isn't long before figuring out what it is and where all the prize money goes.
Old September 15th, 2014, 12:34 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I'll vote for the wiring harness that goes to the fuel pump on its way out. Is it happening more and more often?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 15th, 2014, 04:29 PM
Contractor's Avatar
Contractor
Will
1969 IIA
It has only happened like three or four times over the last couple of weeks.
Ignition module is easy enough to switch out I guess. This truck has an interesting ignition switch set up. It has a toggle switch that turns the truck "on" and then a start button. Not any kind of key switch. I suppose one of those could be bad but I kinda doubt it.
Old September 15th, 2014, 08:29 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
So I have had this scenario twice in my decade or two owning my truck. The first time was the ignition switch which you have ruled out. The second time was the alternator. Yep, alternator. You can search for the threads here, but the jist of it is that I had some A/C bleed into the wiring harness which throws off the fuel injectors when it gets to a specific amount/frequency/rpm. It was always RPM specific and I believe it was 2400 rpm or there abouts.
Zenier diode went bad. Fixed it and the problem has been solved since. Very difficult to find that cuprit...
So, worth checking. You can start by putting your multimeter on AC and seeing if you get anything, or take it to an autoparts store. Bench testing is best.
Just an idea---good luck.
(BTW, if it is warm enough to get really hot where you are, definitely take a look at your ignition module. If it hasn't gone bad, it will, and it usually manifests when it gets hot. This is one of the symptoms, as is staying stalled and not restarting for a few. At very least, relocate it if not already done so).
Old September 18th, 2014, 09:24 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Small update.
I have not had any time to really screw with this thing, but it has gone from intermittent stallings/shutdown to completely cutting off.
I rolled the dice and drove it today to work just trying to see what all happened. Early when the truck was cold this morning sure enough I hit 3rd and it starting cutting out.
On the way home from work, same thing........hit 3rd and it lost power/cut out. Less than 1/8 mile later it stalled completely. I pulled over and it would turn over and start for less than 1 second and then shut down. I did this for about 15 times thinking I was going to have to say screw it and go get my trailer, but eventually it started, ran fine and I got home.
Anyway, I'll add that to the "story" and see what other ideas you all might have.
93 NAS 110 cuts out when put into gear l*factor Defender Technical Discussions 18 June 11th, 2014 06:38 PM
defender 2.5 n/a diesel cuts out like it has water in the fuel sampsonone Defender Technical Discussions 3 November 8th, 2013 08:04 PM
Period-correct off road lights o2batsea Series Technical Discussions 15 October 9th, 2013 01:37 PM
93' nas 110 motor cuts out MRROVER Defender Technical Discussions 0 May 10th, 2010 04:10 PM
Best NAS Lights period!!! FlaD90 The Vendors Loft 9 April 6th, 2010 12:21 PM
