3.5L V8 Rover Engine - am I missing a part here? - Defender Source
Old April 2nd, 2013, 03:11 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Guys,
I have a 3.5L V8 Rover Engine ('83), with a carburetor. Whenever I'm driving, I get an intense exhaust leak smell, sometimes causing pounding headaches... I looked in the engine bay, and it looks like the passenger side exhaust manifold has been modified in the past, letting exhaust leak freely into the engine bay...attached are the pictures for reference. Can anyone tell me what's going on here? Thanks.
ID:	69463   Click image for larger version
-Ryan
Old April 2nd, 2013, 03:19 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
If that's what I think it is then it isn't actually open to the exhaust gasses. It looks like a pre-heater for the inlet. There would have been a pipe from the front of the truck to one of the holes, the other would go to the intake air cleaner. The air passes over the manifold and gets warmed up before it goes into the engine. Its a cold weather mod.
Been a long time since I seen one though so you might want to check. It should not be open to the exhaust gasses in the manifold.
Edit - That's probably not the original air cleaner. The original would have been enclosed and had a single pipe inlet. The hose from the manifold would attach to that in cold weather.
Old April 2nd, 2013, 03:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by BEIS View Post
Guys,
Have someone close off the exit pipe (tail pipe) at the very end of the vehicle and you should be able to see and or feel the leak.
Then fit it or have it fixed.
Originally Posted by ipgregory View Post
It looks like a pre-heater for the inlet... the other would go to the intake air cleaner. The air passes over the manifold and gets warmed up before it goes into the engine. Its a cold weather mod..
Exactly
RDavisinVA
Old April 2nd, 2013, 03:25 PM
BEIS's Avatar
BEIS
RYAN BEIS
I have heard about the cold weather mod before...However, those open pipes and it being so close to the exhaust manifold kind of made me think that it was somehow connected to the exhaust causing the intense exhaust smell.
So I take it, that those pipes are not connected to the exhaust? Sure looks like it.
Also, should those pipes be plugged?
I've never seen another Rover V8 that has this...
-Ryan
Old April 2nd, 2013, 03:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
So I take it, that those pipes are not connected to the exhaust? Sure looks like it. Also, should those pipes be plugged?
No and no
RDavisinVA
Old April 2nd, 2013, 03:28 PM
BEIS's Avatar
BEIS
RYAN BEIS
Exactly
Good call man. I'll try that out. What's a good blocker for the exhaust pipe?
Sorry for the stupid question, just trying to DIY.
------ Follow up post added April 2nd, 2013 02:29 PM ------
No and no
Thanks, Robert. I'm a newbie at engine maintenance.
-Ryan
Old April 2nd, 2013, 03:29 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I have heard of that before...However, those open pipes and it being so close to the exhaust manifold kind of made me think that it was somehow connected to the exhaust causing the intense exhaust smell.
Easy to check like Robert says. Block off one of them and see if you have exhaust gasses coming out. Its possible the manifold is cracked and bleeding into it. They were pretty common on older cars in the UK.
Trying to remember if there was an early version of EGR that had a flap or something in there to let exhaust back into the inlet. Don't think there was but its possible and the flap could be stuck open or something.
Either way it should be pretty easy to verify if you have exhaust coming out of there with the engine running.
Old April 2nd, 2013, 03:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
What to use to block the pipe...
Use some old cotton rags or cotton shop towels or bath towels.
Nothing that was used with flammable liquids or that is made of paper.
I usually wet them first and wear a glove to protect my hands.
Exhaust gas is hot.
RDavisinVA
Old April 2nd, 2013, 03:52 PM
BEIS's Avatar
BEIS
RYAN BEIS
Yall are great. I'll try all of this out, and post the outcome. Thanks!
-Ryan
Old April 2nd, 2013, 03:57 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Come on guys this is the oldest prank world wide, you never shoved a potato up some kids exhaust pipe before, kinda funny watching the out come.
Kinda like running a leaded pencil down a spark plug, this works best on motorcycles
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 2nd, 2013, 04:05 PM
BEIS's Avatar
BEIS
RYAN BEIS
Oh, I'm not plugging the exhaust pipe completely. Just enough to see where that leak is and so it doesn't stall out.
I'm aware of that potato prank, hah.
-Ryan
Old April 2nd, 2013, 04:11 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Potato in the pipe damage...
It can do harm like blow out seals or damage the muffler internally...
Think you were probably kidding, but not a good practice.
RDavisinVA
Old April 2nd, 2013, 04:43 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Seems you are missing the original air filter canister/output to the engine
ID:	69466   Click image for larger version
MUDSUX
Old April 2nd, 2013, 04:55 PM
BEIS's Avatar
BEIS
RYAN BEIS
I guess those pipes were idled by a previous owner, and the carb takes the filter canister's place. Thanks for the pictures MUDSUX!
-Ryan
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
With the removal of the original carbs and aircleaner for the use of the round air cleaner and (I assume) a Holley or similar carb and manifold, I expect that almost all of that stuff had to be removed.
Murph
------ Follow up post added April 2nd, 2013 04:57 PM ------
You can also use a little bit of Seafoam or similar fuel system cleaner. You'll clearly see smoke from where the leak is.
Looking at your photos again, the original dual carb setup and manifold was replaced with an Edelbrock manifold and probably an Edelbrock 1401 or the like carb.
On my first Defender-thing hybrid that had a 3.5 V8, the original carbs and manifold on it were pretty thrashed when I bought it. I bought the Edelbrock manifold like that one (for a Buick V8), 1401 carb and sweet wrinklecoat air cleaner. Then, to really put the cherry on top, I found a set of billet adapters from the UK that allow the use of US musclecar valve covers, and added the Edelbrock valve covers, too. It looked like a musclecar engine and ran pretty good.
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old April 2nd, 2013, 04:58 PM
Ian is right. There would have been hoses attached inbetween to the two carbs and the air filter. There would have been valves on the hoses that closed when hot, but when not enough allowed drawing in air over the exhaust manifold to aid in cold running. But this has nothing to do with smelling fumes. Janey had these, but don't have any pictures handy
Originally Posted by pendy
I'm here for the D's
Old April 2nd, 2013, 05:10 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Ryan, when I fitted that intake and carb for Derek- what 5 years now maybe?-I had put the original air filter housing and all of the bits in the car.
The carb has fuel mixture screws to adjust the amount of fuel used in the idle circuits. Sounds to me from what you've described, she may be just a touch rich.
Trevor
Email is
Same place, new dogs.
Old April 2nd, 2013, 05:15 PM
BEIS's Avatar
BEIS
RYAN BEIS
Trevor
Trevor! There you are! Thanks for chiming in. Yea those parts that were in there are unfortunately long gone. It's been restored, bulkhead swapped, frame swapped, moved across the U.S. twice, and stored for a couple years...so those things naturally go missing hah. Just now...after 5 years, I'm getting to use it on a regular basis. PM me your phone number if possible, would love to catch up.
-Ryan
Old April 2nd, 2013, 06:20 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
My 83 110 has the same set up on the manifold, they do not let exhaust through unless the manifold is cracked open at that exact spot.
Unknown Author
716-898-8153
Old April 3rd, 2013, 10:23 AM
BEIS's Avatar
BEIS
RYAN BEIS
All, found the exhaust leak. It is underneath the cold weather mod... Where the manifold connects with the exhaust pipe. I think (hope) it's a loose connection, and not a blown gasket seal. Didn't have the right deepwell sockets to make it work last night. I think tightening it to see if it's a lose fitting is the first step...crossing my fingers that I don't break it off, or round off the bolt....
-Ryan
engine, part, v8
V8 Engine Swap neduro Defender Technical Discussions 23 August 8th, 2013 11:43 AM
hate to put a jeep part on a land rover mattdh Misc. Chit-Chat 20 November 11th, 2005 08:58 PM
URE Uwharrie Rover Expedition 22-24 October, 2004 Uwharrie NC Dan Trips, Trails and Events 0 September 19th, 2004 09:01 AM
Take out V8 engine and trans--complete evilfij Wanted 9 June 17th, 2004 06:00 PM
