3.5L V8 Replacement Options - Defender Source
Old December 26th, 2013, 09:28 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
What are the best and easiest replacement options for a mid-80's 3.5L V8? I am considering both carb and EFI options. Interested to see which requires fewest replacements of ancillaries.
"These are the best traveled nuts on d-90 . . ." ABrooks
Old December 26th, 2013, 09:45 AM
To my mind, easiest would be a 4.2 with a carb. Up a notch in both performance and complexity would be a 4.6 modified to run a dizzy.
Define "best". Spending least amount of money? Time? Labor?
Old December 26th, 2013, 03:10 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Why do you want to replace the engine? From the research I have done, replacing the camshaft & going to a single carb setup will likely give you a lot more power. Plus the 3.5 was one of the best engines ever put in a Rover.
Hope it works out either way!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 26th, 2013, 03:24 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I went with a 3.9 v-belt out of a RRC with a upgraded cam, intake and holley carb. It was pretty straightforward. The only real issue was getting the power steering hoses to work out. I used all RRC ancillaries on it. Bigger alternator and easier to find parts with all the RRC's getting scraped.
Unknown Author
716-898-8153
Old December 26th, 2013, 09:05 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Best in my mind is a combination of performance and reliability. I am looking for an application for a 130 so my primary concern with the 3.5L as it stands is simply performance. I am open to modifying the 3.5 to improve performance or a swap.
Old December 26th, 2013, 09:11 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
3.9's in my mind are extremely reliable for a Rover motor.
Unknown Author
716-898-8153
Old December 26th, 2013, 10:55 PM
robertf
Robert F
1995 Discovery
IMO all the problems are from the thinner cylinder wall, so if you are going 3.9 you might as well go 4.6 as long as you can get a decent block. That said, I've had a 4.6 on the engine stand for about a year just because I'm not ready deal with the heartache of finding out its got a bad block.
Old December 26th, 2013, 11:02 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
I honestly never see the issues with the 3.9's. It's always the 4.0/4.6 that seem to have issues. All my 3.9's have always been reliable knock on wood
Unknown Author
716-898-8153
Old December 26th, 2013, 11:06 PM
jafir's Avatar
jafir
Jafir Elkurd
The 3.9 used to blow head gaskets all the time. They issued an update to use the newer gaskets and leave out some head bolts.
Old December 26th, 2013, 11:07 PM
robertf
Robert F
1995 Discovery
I've had 2 3.9s die. The first one was replaced by the dealer. 100k later it had a tensioner fail while towing and overheated, got about a year out of it before cyl 5 leaked. It looked ok so I wasted $ on headgaskets only to verify the block was trashed.
Had a GEMS 4.0 go on cyl 7, visibly cracked through the liner.
cool story, I know
Old December 26th, 2013, 11:17 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Tensioner failure could happen on any of them, so cool story bro lol
I still prefer the 3.9 to the 4.0/4.6
Also I have the composite gaskets with the left out head bolts.
Unknown Author
716-898-8153
Old December 26th, 2013, 11:43 PM
robertf
Robert F
1995 Discovery
Tensioner failure could happen on any of them, so cool story bro lol .
yup, which is why I now carry a spare and glance at the tachometer every 30 seconds while driving
I still think a 3.5 would have had a better chance at living through that failure, so if that peace of mind is gone go for the displacement.
Alternator Replacement Options for Disco 200tdi isleofbones Defender Technical Discussions 7 February 23rd, 2013 03:27 PM
Transmission replacement options michael67 Defender Technical Discussions 3 October 13th, 2011 01:01 AM
replacing 3.5L V8 rear main oil seal cgalpin Defender Technical Discussions 9 June 18th, 2008 01:03 PM
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Transmission Replacement Options??? JRowe Defender Technical Discussions 17 October 14th, 2003 10:46 PM
