3.5 won't rev under load - Defender Source
Old June 1st, 2014, 12:36 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Idles fine, revs to redline without issues under zero load, but when driving it revs fine to 1/4 throttle, then acts like it's fuel starving something shocking. It helps a bit if I pull the choke out, but even when she's up to operating temperature, it won't rev worth a crap (revs increase but not correctly, sounds like it's missing).
Any ideas?
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old June 1st, 2014, 01:12 PM
Blown diaphragm in one of the carbs ? Fuel filter issue ?
Old June 1st, 2014, 01:22 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys!
Fuel filter was just replaced. Will check the vacuum lines, and the vacuum advance and advance weights on the distributor and the carb diaphragms.
Plan to swap the 3.5 for a 4.2 as soon as funds allow...
Old June 1st, 2014, 01:27 PM
What changes since it last ran right?
Old June 1st, 2014, 02:06 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
If you are looking to put a 4.2 in, what fuel system are you planning on running? If you are considering an Edelbrock you might try it out on the 3.5 first.
-Jeff
Fuel injected 4.2. Likely stock f.i. system unless there's something better? I considered putting a single carb on the 3.5 but was advised that it wouldn't add much power. I need more power.
Good question. Basically, it sat overnight after a road trip (260 miles) during which it ran great. It didn't want to start the next morning, and had a really bad gas smell. Hasn't run worth beans since.
Old June 2nd, 2014, 06:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update:
Drove it 1/2 mile to the gas station yesterday, ran like crap all the way there & back.
Fired it up this morning- ran great! Took her a couple of miles along the freeway & back on the secondaries- no problems at all.
Will let you know if it happens again.
Paul.
Old June 2nd, 2014, 08:01 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Secondaries? What carb/manifold are you running?
-Jeff
Stock, whatever that is. I think they are SU.
Old June 3rd, 2014, 12:10 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I was confused (dual side drafts don't have secondaries) You might double check the oil level in the carbs as well. -Jeff
pretty sure he means secondary roads.
Jimmy Buffett
Old June 3rd, 2014, 12:28 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I think they are probably strohmburgs. That is what my 3.5 had.
Unknown Author
716-898-8153
Old June 3rd, 2014, 02:53 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could it have been bad gas? It has happened...albeit rare. If the only change was the gas, then my guess would be carb related or bad gas, possibly water or sediment contamination. I know that I had an idle jet loosen on my motorcycle once and giving it gas flooded those cylinders and it wouldn't run well but idled just fine. I am not familiar with your carbs, but similar condition. Since it runs fine now, without further change, gas contamination/clog of some sort seems likely. A vacuum leak would be next on my list and if it is a cracked line, that can seem to be intermittent...
Genuine td5 rev counter/tachometer myoverlandrover Wanted 0 April 25th, 2013 09:54 PM
FYI.. D90 Front Calipers have been rev'd with new parts rlynch356 Defender Technical Discussions 2 May 9th, 2011 10:15 PM
TD5 rev counter d90dang Defender Technical Discussions 3 December 12th, 2010 04:18 PM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
rev limiter rover4x4 Misc. Chit-Chat 3 May 27th, 2004 09:04 AM
