3.5 V8 with Edlebrock Manifold - Defender Source
Old April 4th, 2014, 07:34 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I had to replace my valley pan so I have decided to replace all the worn hoses and such. My question is I was wondering if the heater hose going to the water pump can run under the manifold and on top of the valley pan? Also when I took the hoses off I did not mark (stupid me) the water pump to which outlet on the water pump it connects. As looking into the engine bay is it the right or left on the back of the water pump. Thanks
1983 ROW D110
1970 Series III (Parting out)
Old April 4th, 2014, 08:58 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
hose out of the pump housing goes to the right side of the steel heater pipe . the manifold outlet goes to the left side of the heater pipe assembly...the steel heater pipe assembly is above the intake manifold
see RN for reference
No Mall crawler here
Old April 4th, 2014, 09:38 AM
Yes, the heater hose(s) can and normally go under the Edelbrock manifold, on top of the valley gasket.
Old April 4th, 2014, 10:43 AM
thats the fuel injected setup. Early carbed 3.5's don't have the metal heater pipes
Old April 4th, 2014, 11:08 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Im a ass wasn't paying attention , but would not run rubber heater hoses under the intake but that just my .02
Old April 4th, 2014, 03:38 PM
usadventureracing
Brett
110
Thanks for the replies....now I have to determine if I go under the manifold with the heater hose. If I do I will get a better seal to the water pump as I think some of my coolant leaking was how the hose was bent, not allowing for a good seal. So the hose looks to attach at the right side on the water pump when looking into the engine bay.
1983 ROW D110
Old April 4th, 2014, 04:16 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Brett, sunday night I can check and see if I have a metal pipe of off a Range Rover laying about. I think I might but I'm not positive. If I do you can have it.
Unknown Author
716-898-8153
v8
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
replacing sensors in manifold mattdh Defender Technical Discussions 3 September 20th, 2004 07:33 PM
Twin carbs and manifold kellymoe For Sale - Parts 2 July 29th, 2004 01:12 PM
Complete intake manifold orlandog For Sale - Parts 0 February 29th, 2004 12:43 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
» Defender Registry
Big Red
jec
# 115
wineryrover
Add your Defender
