3.5 V8 Throttle Problems - Defender Source
Old February 27th, 2016, 09:14 PM
Tarheeld
Bill
1985 110
Hey folks,
I have a 1988 110 3.5 V8 (no mods). On startup, with the choke pulled out, the engine revs all the way to 7000 rpm and stays put with no indication of letting down. I had a quick look at the choke spring in front of the carbs and it was stuck so I unstuck it. I also noticed Cable B had come loose with the ends frayed. I connected a new cable with a wire clamp and threaded it back through Nut D. Still no difference on starting it up. Its never done this before and was a turn key defender as strange and rare as they come. Also, the accelerator pedal only returns halfway after being fully depressed? Any suggestions/tips would be helpful
PS: What does Cable B do? I understand Cable A is the throttle cable connected to the accelerator.
problems, v8
D90 throttle pedal assembly and throttle cables Willard For Sale - Parts 2 October 14th, 2008 10:31 AM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
Off-Throttle Clunk... P1CR Defender Technical Discussions 2 April 7th, 2004 03:20 AM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
