3.5 V8 "Sputtering" when cold or sitting for several days - Defender Source
Old August 10th, 2015, 10:13 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
3.9 V8 "Sputtering" when cold or sitting for several days
(Edit...meant to type 3.9)
When my 94 D-90 (3.9 V8) sits for several days, it "sputters" when I first start driving (sounds like a cylinder missing)
I just power through it with heavy use of the right pedal and after a mile or so it completely goes away.
It seems like it has to sit > 24 hours for it to happen.
Any ideas?
Dave
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old August 10th, 2015, 10:42 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Have you ever serviced the carbs? Maybe grab a workshop manual and see what is suggested in terms of regular maintenance. I understand if the fluids in the pots runs low then the system can start to act up. I also understand the wrong fluid in the pots will cause the system to fail. Maybe find a British car shop that knows how these things are supposed to be set up and managed.
Old August 10th, 2015, 11:26 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
No carbs. 3.9 EFI
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 10th, 2015, 12:13 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by DMSLongLake View Post
No carbs. 3.9 EFI
check your battery. Mine does this if I forget to plug it in and don't drive it a couple times a week.
Jimmy Buffett
Old August 10th, 2015, 12:33 PM
LRover's Avatar
LRover
J. Michael McCaig
Spark plug(s) could be fouling from a leaky fuel injector(s).
Old August 10th, 2015, 01:18 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Dual batteries and both are 100%
------ Follow up post added August 10th, 2015 12:19 PM ------
Would that clear itself when it warms up?
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 10th, 2015, 03:43 PM
LRover's Avatar
LRover
J. Michael McCaig
Pull a spark plug when it's missing. If it looks wet and dark gray or black chances are it's getting too much fuel. If it is light gray or white it is something else. If it is only happening when the engine is cold, check the connection for the fuel sensor on the fuel rail. I recently had a problem with a bad sensor connection causing similar symptoms until the engine warmed up.
Old August 10th, 2015, 05:07 PM
azlandrover
stephen gross
1959 Landrover
Is the engine consuming coolant? If you need to add coolant or water that indicates a slipped/cracked liner and coolant entering the combustion chamber which will result in misfire on that cylinder. Also, after the vehicle has reached operating temperature, are the radiator hoses rock hard? If the cap on the expansion tank is removed (when engine cold) is there a hydrocarbon/exhaust odor in the tank? If so, you have a leak.
Old August 11th, 2015, 09:25 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
No coolant leaking. And ran like a champ today. So it seems like it only happens when sitting for days...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 11th, 2015, 09:59 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Possible air getting into fuel line (cracked line, bad fuel pressure regulator)? You could toss a fuel pressure gauge onto your line and see it is holding pressure. Could easily be your fuel pump too. My RRC had similar intermittent pump before it failed, but it wasn't just after its sitting. I also second the leaking injector-- seems to make sense.
Old August 17th, 2015, 03:43 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
So interesting update (have not had time to dig into it.).
My fuel tank was close to empty yesterday and each time I made a hard left turn, the sputtering for bad until the tank leveled out. Right turn did not do the same.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 17th, 2015, 06:32 PM
So interesting update (have not had time to dig into it.). My fuel tank was close to empty yesterday and each time I made a hard left turn, the sputtering for bad until the tank leveled out. Right turn did not do the same.
tanks don't have baffles so fuel starvation sounds likely.
v8
Sitting at work JBurt Misc. Chit-Chat 104 December 23rd, 2016 08:13 PM
WTB 1 Jumpseat (could be just the sitting part) and 2 seatbelts for RT jumpseats. beko35 Wanted 3 June 24th, 2009 01:39 PM
Sitting D-90 mikeybob2@msn.com Defender Technical Discussions 8 March 23rd, 2008 06:48 PM
Sitting Level - OME & ARB Bull Bar w/ Warn Winch TurkD90 Defender Technical Discussions 23 January 5th, 2005 10:44 AM
