3.5 V8 questions - Page 3 - Defender Source
Old February 22nd, 2011, 06:40 PM
I have typically found you need at least 2 quarts to go from off the dipstick to full, but let us know how much you end up using.
Originally Posted by pendy
I'm here for the D's
Old February 26th, 2011, 07:09 AM
usadventureracing's Avatar
usadventureracing
Brett
110
So far 8.5 quarts and just now on the tip of the dip stick.
1983 ROW D110
1970 Series III (Parting out)
Old February 27th, 2011, 12:37 PM
usadventureracing
Brett
110
Ok 9 quarts now and the dip stick says to still add more. My dip stick measures 21 3/4 inches from the end to the top (top where the ring is at). Could anyone with a 3.5 check to see if the length is the same.
Thanks in advance,
Brett
1983 ROW D110
Old February 27th, 2011, 01:03 PM
pendy's Avatar
pendy
jim pendleton
89'd90
That is to much No more then 7 You are going to cause damage. Take some out until you find another dipstick assembly
legend in my own mind
Old February 27th, 2011, 09:10 PM
Is a diptsick from a D90 good for that engine? If so, I can send you one. Too tired to go out and measure it right now, but will at some point if that helps.
Old March 1st, 2011, 12:02 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I just checked the manual - it says that oil capacity with filter replacement for the 3.5 liter V8 should be 11.6 US pints or just shy of 6 quarts. This is from the Land Rover V8 Repair Operation Manual Supplement from 1981.
On another forum (Stage One) an Australian measured his dipstick to the bottom of the collar to be 539mm or about 21.25 inches. If you are measuring to the top of the collar then yours is right.
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 1st, 2011, 07:04 AM
usadventureracing
Brett
110
Thank you all for the info, I am going to drain the oil this weekend and start over. Looks like I have the correct dipstick, maybe it is installed wrong as I did not have any oil on the dipstick after 7 quarts.
Thanks again,
Brett
1983 ROW D110
v8
1985 3.5 V8 engine mounts tomaco1 Defender Technical Discussions 10 December 18th, 2013 10:36 PM
3.5 V8 vs 200 Tdi bbdesoleil Defender Technical Discussions 15 August 29th, 2010 10:17 AM
3.5 V8 Timing Chain Renewal MUDSUX Defender Technical Discussions 15 December 11th, 2009 05:21 PM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Throttle Body Injector (TBI) for 3.5 V8 gregorw47 Defender Technical Discussions 9 January 8th, 2006 12:55 PM
