3.5 V8 checking tension of water pump belt - Defender Source
Join the Defender Source Community Today
Old August 2nd, 2016, 07:01 AM
Yorkie
Mark Whitehouse
1989 D90
How do I do it. Remember I know sweet FA about mechanics. So even identifying the correct belt would be helpful. My V8 has had the original fan replaced with and electric one which I assumes makes a difference to the setup.
Mark
Old August 2nd, 2016, 08:32 AM
From the belts static/stationary position, grab it in a place where there is lots of space between pulleys. How far can you move it ?
2 inches -ie 1 inch in either direction is about right.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old August 2nd, 2016, 08:52 AM
LR Max
Thomason, Max
1973 Series 3 109
I bought a belt tension gauge. Cheap off amazon:
That is what many industrial engine manufacturers recommend having as a normal tool.
v8, water, water pump
releasing belt tension on '85 v8 fan belt Chris Velardi Defender Technical Discussions 6 January 13th, 2014 04:18 PM
Water pump tension pulley Surf90 Defender Technical Discussions 19 February 5th, 2013 12:09 PM
Corect V belt tension 3.9 wantone Defender Technical Discussions 10 February 4th, 2013 10:23 PM
any 95, 3.9 water pump tension pulleys out there? snosrfr Wanted 8 October 28th, 2010 10:20 PM
belt tension on a 95? durangorover Defender Technical Discussions 2 June 3rd, 2009 10:37 AM
