3.5 twin carb switching to twin K&N air filters - Defender Source
Old October 19th, 2014, 12:17 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
Folks - was thinking of taking out the original air filter can and replacing with a pair of K&N filters on my twin SU carbs.
Its a 1988 and I have an exhaust gas recirculation system (metal tubes coming off exhaust manifold to a small header on each side of engine with 1" hoses that join just before going into the 3" breather pipe between the carbs and air cleaner
Plus I have one rubber hose from one of the valve covers also into the same 3" breather pipe.
So the the existing system is pulling from these connections and recirculating these gases back into the carbs.
It seems safe to block the egr hoses from the two small headers (that gas will just go out the exhaust pipe). BUT what about the rubber hose from the top of the valve cover? Block it? leave it open? If I leave it open it might be a mess. If I block it will it build air pressure inside the valve cover?
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old October 19th, 2014, 08:16 AM
LRover's Avatar
LRover
J. Michael McCaig
you will need to route the breather from the valve cover back to the air cleaner somehow. If you block it off, pressure will build up in the engine and will cause all the seals to leak way worse than they may do now because the pressure has no where else to go. If you drive a lot of dusty roads, you may want to consider leaving the original air cleaner as it does a pretty good job.
Old October 19th, 2014, 09:21 AM
I'm in agreement. K&N products really add nothing useful to a LR product. You don't say what you are trying to solve with the proposed mod but I suspect messing with emission related item (EGR) might be a no no.
I removed it all. The pipes screwed into the head will unscrew and a stubby bolt of the same thread fixes that issue. The engine is far easier to work on with all of that removed. That said given your location wouldn't you want to keep the warm air warm up setup ?
Old October 19th, 2014, 10:11 AM
rovertrader's Avatar
rovertrader
Dale
They also make a filtered cap for the valve cover issue
Old October 19th, 2014, 12:12 PM
akrockhound
Jack
1988 RHD 110
good advice but a couple questions
I was considering doing this because the K & N folks boast about their products breathing better than conventional air filters so they give better performance. Also they are serviceable/reusable.
I have a K & N on my Chevy duramax and like it.
Doug you mentioned that the original set up has an air warming function. Yes that seems like something I should be keeping up here. Which part of the setup provides this function? Is it the gas recirculation from the heads? Is it the fact that the whole intake system rests on top of and behind the engine which has a warming effect?
I ask so I can make a more informed decision whether to do this or not.
Is there anything that could/should go that will help with performance without degrading the functionality? I.E anything that strictly has an air pollution function and nothing else?
'01 Disco II
'95 RRC LWB
Old February 16th, 2015, 12:44 AM
RBBailey
RBBailey
1965 IIa
Happened across this thread.
I would not be driving a licensed vehicle right now if I have not removed the stock filter(s) and put KN filters on the SU carbs.
switch
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
AirRaid vs. K & N air filters cdb Defender Technical Discussions 6 December 14th, 2011 03:59 PM
Are K&N, Amsoil, etc air filters worth it? cdb Defender Technical Discussions 8 July 19th, 2007 08:38 PM
twin SU carb and intake off of a 3.5 draaronr For Sale - Parts 1 January 1st, 2005 11:28 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
