3.5 to 3.9 install - Defender Source
Old February 6th, 2006, 02:08 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
3.5 to 3.9 install
I am tossing around the idea of replacing my 3.5 carbed for a 3.9. I dont want the EFI and will be using my carb and intake manifold on the 3.9. I dont want to mess with trying to make the EFI work on my truck. I am guessing it will be a pretty straight forward switch. Any hiccups I might run into?
Kevin
Old February 6th, 2006, 12:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
What year is the 3.5 you're replacing?
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 6th, 2006, 01:00 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
It,s out of a 1988 Defender. it has 180k miles on it.
Old February 6th, 2006, 01:24 PM
Hans's Avatar
Hans
Hans Haase
Ok, then it has the same oil pump setup and distributor. Should just bolt right in IIRC.
-Hans
My oil line fix
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
3.5 vs 3.9 rgrrvr Defender Technical Discussions 1 April 23rd, 2007 04:13 PM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
3.5 or 3.9 block draaronr Wanted 1 November 15th, 2004 10:56 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
