3.5 dual carbs dumps fuel out lines - Defender Source
Old September 26th, 2013, 11:09 AM
Nate6472/
Nate
88 D90 V8
I have a D90 and there are spill lines off each carb which sometime expell fuel. What is this about?
Old September 26th, 2013, 12:55 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
The parts manual calls these "vent pipes". My 110 has them as well. I can't give you the mechanical reason as to why they are there, but I'm sure someone else will chime in who can.
Most days, nothing comes out of them. In warmer weather, or after a long road trip, they will leave a couple drops of fuel on the garage floor. As long as you're not gushing fuel from them, you're fine.
Cheers,
Old September 26th, 2013, 01:16 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Carb float valve is sticking allowing excess fuel to overfill the fuel reservoir.
RDavisinVA
Old September 26th, 2013, 01:23 PM
Nate6472/
Nate
88 D90 V8
Easy, quick fix? Only does it sometimes
fuel
Dual Fuel Tank Gremlins nimbusnic Defender Technical Discussions 1 June 24th, 2008 01:52 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
