3.5 Carb Help Please - Defender Source
Old June 15th, 2010, 09:01 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
So I am in the process of refilling all the fluids back into my rebuild to get the engine started. I put fuel in the tank and turned on the pump to prime it and I get fuel all over the floor. If you look at the picture it is coming from the carb and coming out the end of the tube. I made pretty good tags when I took everything apart. I do not remember this being attached anywhere. Did I miss something?
I did buy a new external fuel pump rated at 6-8 gph instead of the 4-6 gph. Could this cause too much pressure? Any input would be greatly appreciated. Thanks!
ID:	28596   Click image for larger version
MUDSUX
Old June 15th, 2010, 09:57 PM
Forrest, I don't think fuel should be coming out of those (making me think you might be right about the pressure increase to blame). On Janey these just route to the side of the engine down the to frame where they are open - so they look like overflow/pressure release points, but I am not sure. I'm hazarding a guess that they didn't design it to dump fuel on the ground (in other words i'd think that was an air vent since its right above the intake) so something must be wrong!
I can tell you that fuel comes up in one of those lines that come under the carb and connect to the front, tees off to the other, and then returns on the other side line.
Old June 15th, 2010, 10:15 PM
gph is not the issue, it is psi. The carbs like very low pressure.
Old June 15th, 2010, 10:39 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Whoops, I meant 6-8 PSI not GPH. Is that too high?
MUDSUX
Old June 15th, 2010, 11:56 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I am guessing too high, I had the same twin carbs you had and I think 5 psi is too high at times so I bought a fuel pressure regulator and dialed it down to 3.5 psi and it works just fine. A fuel pressure regulator may be your cheapest and easiest diagnostic tool for this problem.
Doesnt the lines you are talking about go to the air filter box?
BTW upgrade to an Edelbrock 1404 and 2198 intake manifold.
Old June 16th, 2010, 12:19 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by kellymoe View Post
Doesn't the lines you are talking about go to the air filter box?
I don't know. I don't remember it going anywhere. It just hung off the back of the engine. I think.
3.5 PSI? I can't remember where it should be at. I remember reading 4-6 was normal that's why I bought this pump.
MUDSUX
Old June 16th, 2010, 10:00 AM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
Hi Forrest,
Those are vent pipes. The factory set-up has a single pipe coming from each side, and then routes them down along the side of the engine to the frame. Check out my photos (if I've attached them correctly!)
I agree, fuel should not be shooting out of these things, but with that said, I've had a couple drips of fuel from these pipes after extended driving on a hot summer day.
ID:	28599   Click image for larger version
Old June 16th, 2010, 10:54 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by mcoleman762 View Post
Hi Forrest,
Thanks Mike, that really gives me a piece of mind. Do you know what PSI you are running at?
MUDSUX
Old June 16th, 2010, 09:17 PM
mcoleman762
Mike Coleman
Hmm...I really don't know, and I'm not sure how I'd check it to find out. However, I am running the factory fuel pump, and the shop manual says it should be set between 3 and 5 psi. So my best guess is that my system is running at the correct factory psi.
Hope this helps.
Old June 17th, 2010, 12:18 AM
You want it near 4psi from what I hear.
3.5 to 3.9 install kellymoe Defender Technical Discussions 3 February 6th, 2006 01:24 PM
Throttle Body Injector (TBI) for 3.5 V8 gregorw47 Defender Technical Discussions 9 January 8th, 2006 12:55 PM
Carb difference and door panels DIVERPRO Defender Technical Discussions 2 March 20th, 2005 05:31 PM
twin SU carb and intake off of a 3.5 draaronr For Sale - Parts 1 January 1st, 2005 11:28 PM
General consensus question 4.0 or 4.6 to replace 3.5 draaronr Defender Technical Discussions 18 August 19th, 2004 05:25 PM
» Defender Registry
Landy
x-pat
D-Storm
LI90
Add your Defender
