3.5 auto and LT230 ..direct swap? - Defender Source
Old September 11th, 2012, 10:22 PM
Rugbier's Avatar
Rugbier
Gustavo
Does anyone know if an auto tran and an lt 230 from a disco are a direct bolt on to a 3.5 engine?
NO SIGNATURE
Old September 11th, 2012, 10:38 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Are you talking the standard Rover Defender autobox, Zf 4HP22 ?
Old September 11th, 2012, 10:41 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Goose you probably need a Defender bell housing...let me check
Old September 11th, 2012, 11:11 PM
carlosz's Avatar
carlosz
Carlos
Gus yes indeed it is seņor, if the donor was equipped with a 3.9 youre good if the donnor disco had the 4.0 the you need to use the donnor flexplate so you can take advantage of the latter style torque converter... any way you go you could get a trans out of a 4.0 and reuse your 3.5 torque converter.
so long story short yes the bellhousing bolt pattern is the same for all 3.5,3.9,4.2,4.0 and 4.6 engines and yes you can mate lt230 or bw tcases to any of those 4hp22 trannies the 4hp22e and 4hp24e mated to later d2's and p38's will mate as well but need compushift in order to operate on older d1's, d90's and pre p38 rangies as e deciphers electronic.
Old September 12th, 2012, 05:54 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by carlosz View Post
yes you can mate lt230 or bw tcases to any of those 4hp22 trannies .
Chances are if you try to swap in an lt230 for a BW you will need to change the transmission tailshaft (long spline) from a newer version. It's a 2 min operation when holding the right bits.
Matt Browne
Old September 12th, 2012, 07:13 AM
Rugbier's Avatar
Rugbier
Gustavo
The 3.5 it is a 4 speed manual
So how much of a pain in the ass would the job be?
( convert the manual to auto )
NO SIGNATURE
Old September 12th, 2012, 10:04 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Aww. Why do you want to swap out the 4 speed? Does it sound like somebody threw rocks inside it?
Shouldn't be tough. If it's a 90/110 I think you'll have issues with center console jobby. I'd recommend paying the piper and getting a legitimate one(like the Ashcroft type) or moving the shifter to the original location like in project Pilgrim from LRM rather than make some crackhead console from plywood that looks like turd with the shifter in your elbow.
If it's an older Range Rover I know nothing about that at all.
You little rebel, I like you.
Old September 12th, 2012, 11:02 AM
Rugbier's Avatar
Rugbier
Gustavo
Is a 110 - swapping for comfort
Have all the interior pieces except the tran cooler and the tran mount
NO SIGNATURE
Old September 12th, 2012, 11:24 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I have a 3.5 with an auto trans here is a pic. Not sure what it all includes as it came to this way. The only issue I am having with it is finding an interior trim for it.
1983 ROW D110
1970 Series III (Parting out)
lt230
like new LT230 CDeWan For Sale - Parts 5 August 6th, 2012 05:48 PM
3.9 V8, hp22 ZF trans., lt230 tcase (1.2), early Defender seats tommyd For Sale - Parts 9 February 11th, 2009 12:54 AM
LT230 - difference between auto and manual? jaherring Defender Technical Discussions 3 February 8th, 2008 11:17 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
» Defender Registry
Big D
rtcgb
D-Storm
LI90
Add your Defender
