2nd gear syncro is gone - Defender Source
Old February 2nd, 2010, 07:33 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Down shifting is fine. Upshift requires gently letting the rpms drop and sliding it in. How long will I get out of it and what are the best options?
Thanks.
I'm drive it gently. Id like to just run it for as long as I can.
And hay
And I love you too
Old February 2nd, 2010, 07:45 PM
My 94 has been that way for 30k and seems fine otherwise.
Old February 2nd, 2010, 08:00 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Sweet!
That was the answer I was wanting.
And hay
And I love you too
Old February 2nd, 2010, 08:02 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Mine started grinding about a week after the warranty expired.. that was about 100K miles and 13 years ago.. it's still grinding but I shift carefully, double clutch sometimes, and start off in second a lot.... guess I should rebuild or replace it soon...
1994 D90 #1880
Old February 2nd, 2010, 08:28 PM
Great .... a feature rather than another fault!!
Old February 2nd, 2010, 09:20 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I wouldn't say that. I like to keep up with my cars but I don't feel like pulling the tranny again for a couple of years.
And hay
And I love you too
Old February 2nd, 2010, 11:41 PM
I time mine perfectly and never hear a sound. Since I was the 3rd and 6th owner of it on the test drive for the repurchase (which, BTW, I had to walk home from) it was like an old friend and I remembered the timing perfectly (probably because that is how I drove the other two I have had in between as as result of learning to time it perfectly with the first D90).
Old February 2nd, 2010, 11:50 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
my first to second has been that way since i bought it - just double clutch it - my mechanic says it is not a problem - and no reason to fix it
Old February 3rd, 2010, 01:45 AM
BTW Redline MTL offers some improvement.
Old February 3rd, 2010, 09:55 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Thanks. I'll try that. I recently changed it and put in castrol synthetic but saw no improvement.
And hay
And I love you too
Old February 3rd, 2010, 10:10 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Redline MTL and a cold morning my tranny is almost normal.
I have a tranny available to swap but I'll probably wait until I stumble on a good T-Case and do everything at once (I've had the tranny available for almost a year now). Like everyone else I'm just used to taking my time on the 1-2 shift. I was farting around with Charles' no clutch shifting move and it actually works nicely and keeps the revs higher but for overall driving I just use the clutch and pause for a moment. FWIW, I have added 11k+ miles since I bought it and it came with a bad 2nd gear syncro.
Old February 3rd, 2010, 10:32 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
How good is the MTL in the LT77s when it is cold? My LT77 does not shift smoothly from 1st to 2nd when cold. Would you use straight MTL, or mix with ATF type F? Currently I am using 1 qt of B&M trick shift for ATF type F, and the rest ATF type F. Nice when warmed up.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 3rd, 2010, 11:00 AM
I don't know as I have never run an LT77 in one of my own trucks for very long. People here seem to say MTL is fine for an LT77 as well and I would be inclined to try that.
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
