24 spline conversion - Defender Source
Old January 19th, 2015, 08:47 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I just wanted to throw out a question. I will search forums later for more info. Looking at drop in center sections truetrac and Detroit 24 spline. They will come with 24 spline axles. All coming out of a 97 d90. Are these drop in on a 86 110. Or pre 92 110's.
~ Semper Fidelis ~
Old January 19th, 2015, 08:53 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Rear is a Dana 60 style R&P so it will not fit as the 97 is the drop out 3rd and 100% different. What you already have the in rear can be built up nice and solid for not too much money.
Old January 19th, 2015, 09:14 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
That is pretty obvious I should have looked at the rear didn't realize the 110 are drop out. So the rear is out of the question.
Front?
Thx
~ Semper Fidelis ~
Old January 19th, 2015, 09:15 AM
On the front, it will work. You will need aftermarket 24/23 spline inner half shafts. If the shafts that are coming with it are the later stock 24/32 spline, they won't be of any use.
As Dave says the rear axle is a Salisbury / Dana 60 center, so that won't work. You can get a Detroit for it, if you want though.
Old January 19th, 2015, 09:22 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Great. Appreciate the expertise! Thanks for the quick turn.
~ Semper Fidelis ~
Old January 19th, 2015, 09:37 AM
Just to add to Red90's post, the issue in the front is that the 10 spline front shafts are two parts
Halfshaft: 10 spline to 23 spline at the CV
CV: 23 spline to 24 spline at the hub.
The problem is that Rover never made a factory 24-spline halfshaft which is 24 spline at the diff and 23 spline at the CV. All factory Rover 24-spline halfshafts were 24 spline at the diff and 32 spline at the CV.
So if you want to convert your front 10-spline diff to a 24-spline diff, you need a custom build front halfshaft which adapts from 24-spline to 23 spline (Ashcroft, KAM, etc). These are not cheap.
Here's the good part: The early 23/24 CV in your truck is actually the strongest CV made by the factory, so the resulting components up front are plenty strong.
Old January 20th, 2015, 10:34 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Did 1997 D90s have any changes to rear 3rd member from previous 90 models. I know different motor and trans, but just want to ensure they are all interchangeable.
~ Semper Fidelis ~
Old January 20th, 2015, 10:40 AM
the rover shop
shayne young
Should be all the same.. 3:54 gears..rover style axle..
Old January 20th, 2015, 10:42 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Thanks Shayne
~ Semper Fidelis ~
Old January 20th, 2015, 01:27 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
I have 10-spline front diff. You recommend just staying with the stock setup then?
Old January 22nd, 2015, 01:22 PM
Mind you, I'm not the best person to ask.
My opinion:
  • 1. Do you want a front locker?
    • a. Yes:
      • - Buy 24 spline locking diff
      • - Buy Ashcroft 24-23 spline front halfshafts
      • - Done.
    • b. No:
      • - Stick with the stock front and don't change anything.
Old January 22nd, 2015, 01:34 PM
jrose609's Avatar
jrose609
Jason Rose
My opinion:
    • a. Yes:
      • - Done.
    • b. No:
Thanks, dude
Old January 22nd, 2015, 01:46 PM
So if you want to convert your front 10-spline diff to a 24-spline diff, you need to get the guts out of a 93-95 RRC axle. These are plentiful and cheap.
Fixed it
conversion
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 05:20 PM
36 spline versus 48 spline steering wheels transientmechanic Defender Technical Discussions 31 November 13th, 2013 09:57 PM
24 spline conversion bearings for Series Housings TDI Guy For Sale - Parts 7 August 29th, 2007 06:50 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
