200tdi wiring diagram - Defender Source
Old April 6th, 2013, 01:10 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Ok, so I didn't document my wiring as well as I normally do. I have a CD with all the wiring notes but the problem is my truck is what you can call a red headed step child or mutt of sorts. It is an 85 ROW with a 200tdi from a disco, with a LHD conversion. What I am looking for is the basic earth points and mapping of the main ignition and starter wiring. I have something wrong and I cannot get the truck to turn over. I'm only wanting the main source battery system tips if that makes sense, I also have a main power shutoff switch that is rated for 600amps, I believe that is big enough for the diesel but not for sure. I have a bunch of brown wires and yellow wires that I am not sure where they go. Anyway HELP
Old April 6th, 2013, 09:17 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Call me... I'll PM you the number:
RDavisinVA
Old April 6th, 2013, 10:00 AM
It is very simple.
switched power from ignition switch to starter solenoid
12V positive wire from battery to starter solenoid.
ground from starter body to engine block.
ground from engine block to chassis
ground from battery to gearbox or engine block.
All other vehicle power comes from brown wires connected to the starter solenoid post. In addition, the alternator power wires connect there as well.
The only other power thing (stock), is the glow plugs, which have their own power line to the battery.
The attached file is for an MOD 110, but the main stuff is all the same.
200tdi, tdi, wiring
95 D90 wiring diagram red&yellowrovers Defender Technical Discussions 6 February 4th, 2012 03:25 PM
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring diagram Shane@EVS Defender Technical Discussions 3 August 20th, 2004 08:46 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
