200tdi water pump leak - Defender Source
Old September 20th, 2014, 02:20 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have developed a leak right behind the fan pulley. Took the shroud, fan, and viscous coupling off just so I could locate it. Is that a common place for failure on a water pump less than one year old?
Old September 20th, 2014, 02:34 PM
Britparts I'm guessing?
Old September 20th, 2014, 02:48 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Most likely. I don't recall the source. Could the belt be too tight and cause early failure?
Old September 20th, 2014, 05:33 PM
Absolutely.
Old September 20th, 2014, 09:42 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Do you think your tensioner is not working correctly? Some of the new non OE pumps are bad right out of the box. Best to get an OE quality in my experience. (had the same thing happen)
Old September 20th, 2014, 10:33 PM
Isn't a 200 TDI a V-belt setup?
Old September 20th, 2014, 10:56 PM
It is a V belt.
Old September 21st, 2014, 08:54 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Right, v belt no tensioner. I have been running that belt pretty tight because of a squeaky alternator pulley.
Old September 21st, 2014, 09:35 AM
It should not matter. If it is a year old it should be under warranty.
Old September 21st, 2014, 09:46 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Well in that case I know who I'm calling first thing tomorrow morning
Old September 21st, 2014, 10:32 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Sounds like you be needing a new belt as well
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Leak from water pump bolt Streaky Defender Technical Discussions 9 July 7th, 2014 09:21 AM
200tdi water pump and front cover gaskets Abrooks Wanted 4 September 12th, 2012 10:02 AM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
