200TDI Viscous Fan - Defender Source
Old August 12th, 2011, 05:58 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
200TDI Viscous Fan
noobie to D-90 but have posted before (this is the first appeal for advice though).
I have a D-110 w/ 200TDI that I noticed was getting a bit "warm". Further inspection revealed that the fan unit (viscous clutch type) was spinning pretty slowly given that the engine temp was creeping up to 3/4 on the gauge. Wasn't getting too hot, just a little hotter than normal IMO.
Is there a way to test the viscous fan to see if it is failing/failed? I would like to keep the current system an avoid going to electric fan. I was horrified to learn that RN would have to special order the fan clutch from LR at a cost of $570 (ouch!!)
Assuming the fan clutch is cooked, is there any way to permanently lock-up the clutch? is there really a need for the fan to slip at all?
I'm trying to avoid sinking $570 into one of the most basic/simplistic parts in the entire vehicle.
I'll post a WTB in the correct section of this forum if anyone has a used fan/clutch.
Old August 12th, 2011, 06:30 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
My understanding is that when the motor is warmed up you should not be able to stop the fan. So you can gently stick a rolled up magazine or newspaper in there to attempt to stop the fan. If it stops, it's toast. I think Pendy on this board sells normal fans without clutches.
I am in the same boat as you with my 200tdi.
Semper Fi!
Old August 12th, 2011, 10:10 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
http://cgi.ebay.co.uk/Land-Rover-Dis...-/270358377766
Or this one
http://cgi.ebay.co.uk/Land-Rover-Def...ht_1664wt_1141
See if they'll post it to you
I'm sure a discovery one is the same as a defender one.
Mike Hammond
Old August 13th, 2011, 12:31 AM
Jackie Treehorn
A
1985 (legitimately)
Or this one
Thanks!
I should have thought eBay.UK. It's on its way!
US$55 plus postage is what that part should cost. I realize it's not RN's fault they can only get the part from Land Rover, but geez $570?!?!?
Old August 13th, 2011, 12:44 AM
mikeslandrover
Mike Hammond
Splendid, get it mended.
Glad to have helped
Mike Hammond
Old August 16th, 2011, 12:50 AM
mikeslandrover
Mike Hammond
I can stop my fan most of the time with the engine warm, the fan does kick in but rarely, same with the discovery.
Mike Hammond
Old August 16th, 2011, 07:19 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
If you want to fix it on the cheap...then just replace the bolts that hold the fan to the clutch with longer ones. You really only need to do two of them to make it work right.
200tdi, fan, tdi
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
Viscous fan questions (200tdi) aclarke Defender Technical Discussions 10 June 29th, 2007 02:05 PM
Viscous Coupling & Fan javelinadave For Sale - Parts 3 September 29th, 2005 01:06 PM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
